Adding an "idler" gear for reverse rotation?
I was wondering if adding an idler to my spur gear, than driving the idler off the pinion changes the overall ratio of the transmission.. I've heard of this being done, but nobody ever got in to the dynamics of the ratio, like does the idler now act like a pinion gear?
- Has thanked: 1129 times
- Been thanked: 3919 times
Re: Adding an "idler" gear for reverse rotation?
As long as the idler is not a compound gear (like you see on an Ultima or the early Traxxas cars) then it won't effect ratio. For example, the idler gear inside the trans is not figured into the ratio between the top shaft and diff gears.
I did this bitd with an Eagle that I converted to nitro well before the Nitro Hawk came out.
- klavy69
- Moderator
- Has thanked: 639 times
- Been thanked: 294 times
Closet Traxxas guy... You and scr8p being the closet Kyosho guy should start your own club.
I'm ok with traxxas, as long as it came with white plastics
So my big question is how do you now calculate your final drive with the additional idler, does it affect the pinion/spur/final drive ratio?
i worked out mounting a gear in between, but clueless how it affects pinion spur selection or where to read up on basic gear calculation...now that i got my sensored stuff running in the correct direction, id just go out, run, and temp the motor but id like to know the actual calculation or theory required. if there's an effect on final drive
It doesn't. just use the pinion/spur math times the internal ratio. the idler is 1:1 between the pinion and spur, it doesn't work into the calculation.
- 2699 Views
Last post by filzemail
- 1277 Views
Last post by SFC K
- 5814 Views
Last post by AYKBOBCAT
- 1894 Views
- 1762 Views
Last post by superfly
- 1400 Views
Last post by templeofspeed
- 994 Views
Last post by MONSTER
- 817 Views
Last post by fr3ak317
