B6 Diff in B5 case ?
Forum rules
- Has thanked: 51 times
- Been thanked: 108 times
Since there is no modern AE section I'm posting my question here.
I'm really a sucker for closeout sales. Anyway, do B6 diffs fit into B5 cases? That would help me for a budget Frankenbuggy.
Thanks, Tony
Thanks, Tony
*** POWDER - KING ***
- Frankentruck
- Has thanked: 2605 times
- Been thanked: 2979 times
Re: B6 Diff in B5 case ?
The AE website says B5/B6/B7 all use the same 91419 ball diff gear, but B5 and B6 have different outdrive part numbers. Both the B5 and B6 use 10x15x4 outdrive bearings though, so it seems like there's hope of the diff working.
- Has thanked: 1129 times
- Been thanked: 3919 times
B5 diffs were a little narrower, a couple mm. To use a b5 diff in a b6, they included shims. That said, the DR10/SR10/RB10 use a b5 style diff, it is narrower and fits the B6 case with shims added. That would be the way to go, plus you can probably pick up a parted out DR10 trans cheaper than buying the parts by the piece (as they dont sell it complete like the B6 diffs)
here is a topic from MIP addressing using their diffs from a B5 in a B6 case, it would apply the same as OEM parts would https://site.petitrc.com/setup/associated/setupb6/B6_FittingB5Diff/
- Has thanked: 1243 times
- Been thanked: 639 times
- Lowgear
- Has thanked: 121 times
- Been thanked: 795 times
Any model produced after 1999 goes into the catch-all forum '21st Century Modern.' I've moved this there for you.
- 1140 Views
Last post by RC10th
- 2799 Views
Last post by Groomi
- 1781 Views
Last post by CamplinP
- 2850 Views
Last post by coxbros1
- 1087 Views
Last post by greene-r74
- 47 Replies
- 8847 Views
Last post by KidAgain
- 1062 Views
Last post by Phin
- 2689 Views
Last post by Chewbacca
