I have a grey RPM trans with an 87 tooth spur gear, what would be a good start with a pinion count on a rere gold pan with maybe a 3800 brushless ? and doeas anyone have a copy of the assy instructions for thr RPM trans?
thanx
Grey RPM transmission
- lowrydesign
- Has thanked: 11 times
- Been thanked: 22 times
Re: Grey RPM transmission
The gray transmission was designed for oval/on road use it has a ratio of 1.96:1
the Original stealth ratio is 2.25:1
With that said It's not going to have much low end tourqe but a ton of topend.
If you're just going to run it around on the street for fun you should use a small pinion that way you can minimize the risk of burning up a motor if you get throttle happy for long periods of time.
- 2370 Views
- 529 Views
Last post by Ronbo
- 22 Replies
- 3650 Views
Last post by vintage88
- 777 Views
Last post by Dadio
- 715 Views
Last post by badhoopty
- 1563 Views
Last post by Lonestar
- 2575 Views
Last post by soniccj5
- 2376 Views
Last post by mytimac
Users browsing this forum: Dual and 16 guests
