RPM TRANSMISSION
General info, Q&A.
K-TOWN-KITT
RPM TRANSMISSION
Post by K-TOWN-KITT »
Does anyone know the gear ratio for the grey RPM transmission with the larger than stock idler gear?
030 (320x240).jpg (68.23 KiB) Viewed 2371 times
Been thanked: 3919 times
Re: RPM TRANSMISSION
P/N 8059 8)
K-TOWN-KITT
Thanks gomachv.
DaveM
Has thanked: 727 times
Been thanked: 26 times
Post by DaveM »
Don't mind me I am trying to post a URL,
http://www.rpmrcproducts.com/products/assoc/trans.htm
I hope it works, scroll down the page.
thats the 2.65 truck trans, his is the gray 1.96 oval trans
DaveM
Post by DaveM »
It looked like the 2.65 conversion because of the two top shafts lying there, the RPM 2.65 conversion is a housing with different top shaft.
Do you have a good pic of the oval conversion trans, I have never seen one and did not know they existed?
Cheers, Dave.
it was the same idea as the 2.65 just for oval. I cant find a lot of documentation around but the Dirt Oval Forums probably has some info, or guys like Reggie on here
DaveM
Post by DaveM »
Thank you Gomachv, it is definitely a grey housing, is it the same as my 2.65 conversion? a gearbox housing and top shaft and everything else comes from the stealth trans.
Cheers, Dave.
Yes, new top shaft and case, the rest is stock stealth
