My cut down chassis
My cut down chassis
I needed to cut the sides down on my chassis to repair the damage done by the previous owner. Does this look ok? I took a pencil and drew several variations on the side until I came up with this. I thought that less cutting the better. I had first thought that I was going to cut down the whole side then I thought to my self....WHY?? Now I have to find a way to blend in the bare metal.
Here's before And here is my mod.
- templeofspeed
- Has thanked: 3 times
- Been thanked: 33 times
Re: My cut down chassis
Maybe continue your cut lines:
The cut edge will look fine silver, that's the way a "team" cut would look. Now you'll have to add a bunch of period hop-ups to make it all work out.
Or keep an eye out for an uncut chassis...
I had it drawn out just like that at first. The more I looked at it the more I decided that it really didn't need to be cut that much. It may end up being an odd looking buggy....but it will be my own. LOL
tbfoto
tbfoto
- Mr. ED
- Has thanked: 62 times
- Been thanked: 62 times
if you'd have asked before and mentioned not wanting to cut much, I 'd have told you to use the ' chinese carbon' trick
But since you got this fare already I'd agree with temple here.
- Erich Reichert
Mr. ED wrote:if you'd have asked before and mentioned not wanting to cut much, I 'd have told you to use the ' chinese carbon' trick![]()
Ok now i'm curious.
- templeofspeed
The search function seems to have limited use these days (it doesn't find older posts)Erich Reichert wrote:Mr. ED wrote:if you'd have asked before and mentioned not wanting to cut much, I 'd have told you to use the ' chinese carbon' trick![]()
Ok now i'm curious.
Anyhow, the "Chinese Method" refers to faux carbon fiber, a'la CF decal material. The term first came to use a long time ago in rc10talk, but I can't find the original post. It might have been in the self purging bst.
- Mr. ED
it was an ultima pro chassis and ferretti came up with the nickname if i recall correctly
- 1327 Views
Last post by fordtransman
- 987 Views
Last post by acerpower1
- 682 Views
Last post by SoAzRC
- 763 Views
Last post by JK Racing
- 964 Views
Last post by ra272
- 1711 Views
Last post by Dr. Robotnik
- 23 Replies
- 3624 Views
Last post by fastang
- 908 Views
Last post by mrlexan
Users browsing this forum: Bing [Bot] and 4 guests
