Any straight forward solution to running modern 12mm hexes on my Jrx2? I figured I'd just upgrade the front of the car with RB6 front axles/spindles. I was hoping there was an available hex for the rear.
Thanks,
Kevin
Jrx2 modern wheel adaption
- Has thanked: 7 times
- Been thanked: 11 times
- Has thanked: 100 times
- Been thanked: 205 times
Re: Jrx2 modern wheel adaption
Modern wheels... If I remember correctly the easiest way is to use b4 wheels with a spacer on the stock axle on front.
Mini - T, LST, LST2, Crawler
Micro - Trekker, SCT, T
- RCveteran
- Has thanked: 26 times
- Been thanked: 200 times
B4 wheels direct fit front but rear requires small .125" spacer usually to avoid rubbing or custom works spacer. Im sure you could drill any standard hex to fit rear axle and pin and experiment with wheel offset from there. There are other ideas with regard to changing axles, Google jrx2 modern wheel.
- LosiXXkid
There's always this option to run standard XX or XXX wheels....
http://www.rc10talk.com/viewtopic.php?f=27&t=36070&start=15
- 30 Replies
- 4828 Views
Last post by JK Racing
- 1159 Views
Last post by sgirouard
- 2385 Views
Last post by cyclepsych0
- 1650 Views
- 2955 Views
- 1324 Views
Last post by UltraHIVE
- 47 Replies
- 7752 Views
Last post by License2iLL
- 603 Views
Last post by highwayracer
