Yokomo 834 RPS opinion/question
- klavy69
- Moderator
- Has thanked: 639 times
- Been thanked: 294 times
Re: Yokomo 834 RPS opinion/question
Ringing in with my 2 cents...original all the way
- 59burst
contact to Dave Campbell for the delta rear shocks. the email address is [email protected]
and on the front shocks, I don't know any source for it. but the SE version has a slightly longer front shock than the first 834B. even the front shock mounts are bit different
and Dave doesn't have the aluminum shock ends at this moment but I believe you can use them from 870C shocks
- stickboy007
- Been thanked: 55 times
Whatever tickles your pickle. Nice resto, btw.
My view is there are enough "original" builds out there, and so you're not treading new ground with an original restoration. That's not to say it isn't satisfying or you won't learn anything. It just depends on what you're trying to accomplish. If you want to preserve the history, then do an original restoration like you've done. If you want to be different, then do something different...
- Been thanked: 325 times
+1. Once you've seen one box-art resto, you've seen 'em all.stickboy007 wrote:My view is there are enough "original" builds out there, and so you're not treading new ground with an original restoration. That's not to say it isn't satisfying or you won't learn anything. It just depends on what you're trying to accomplish. If you want to preserve the history, then do an original restoration like you've done. If you want to be different, then do something different...
- RC10resto
- Has thanked: 1487 times
- Been thanked: 550 times
No, I don't think so - never too much RPStamiyadan wrote: i know how bored everyone is of RPS buggies
so final pics and i'm out.
- klavy69
- Moderator
- Been thanked: 12 times
Pargu did some nice lower front arms in alloy.
http://www.pargustore.com/vintage-yokomo-834b-front-arms.html
- 2001 Views
Last post by kustomizerz
- 1816 Views
Last post by Dr. Robotnik
- 2541 Views
- 1888 Views
Last post by Eccentric
- 1657 Views
Last post by mrlexan
- 52 Replies
- 6798 Views
Last post by Bormac
- 94 Replies
- 11595 Views
Last post by GJW
- 2404 Views
Last post by Lonestar
