RC10 B2/3 wheels Shapeways 3D printed as used at 95 Worlds
Ok, thanks to Niki the wheels as displayed on the first proto plastic see through chassis of the 91 Worlds proto that has yellow flat wheels with a big wheel nut hole. Now I know a company in Europe made these (possibly in Sweden) and I got my hands on several sets before the worlds happened as at the time was in line to do it but when I was asked I actually couldnt go due to how expensive Japan is so had to turn it down which I now regret.
However another regret was getting rid of these wheels later on as they made the car look so much nicer, so asked Niki if he could work his magic and do a 3d print and he has.
Pictures below show the rear wheel next to an original B2 version, also with the wheel nut cap (which has a tiny flat spot for a fine screw driver to lift it off) and then on my car with and without the wheel nut cap. I used pink wheel stickers on my car when I ran it, to blend in with the dragon and worked very well for me. Ok cost is a but high however for a shelfer I think its worth every penny, just need to drill the hole a fraction and cut away the wheel cap from behind the wheel and its a perfect fit and stunning. Your thoughts on this as always are always appreciated.
Link here to the wheels on Shapeways
http://www.shapeways.com/product/KTQFE2MS2/special-rim-rc10wc-b2-b3-1pcs?li=shareProduct&key=a6f7e8676874003627f9cc828c252be9
- Attachments
- 6.JPG (17.38 KiB) Viewed 1908 times
- 5.JPG (16.75 KiB) Viewed 1908 times
- 3.JPG (47.09 KiB) Viewed 1908 times
- 2.JPG (47.11 KiB) Viewed 1908 times
Designer of the Lazer ZX / ZXR Tub Chassis (now available again from Fibre-Lyte)
Sponser links below
http://www.fibre-lyte.co.uk/
http://www.kamtec.co.uk/
Sponser links below
Re: RC10 B2/3 wheels Shapeways 3D printed as used at 95 Worl
Do you plan to run these? I'm curious how they would hold up on track.
I may do one day, they do feel almost as strong as the kit versions,these have a better webbing strength in the original designcompared to the original kit wheels so may be up to the job.
Sponser links below
Sponser links below
Cheers, old shell been used a lot and my old dragon design which was designed by Craig Harris for me and Ive used since the B2 got released.Zac_F71 wrote:Looks great! Love the body!
Sponser links below
Sponser links below
- 885 Views
Last post by sandkil
- 30 Replies
- 3126 Views
Last post by joe sumasky
- 32 Replies
- 10622 Views
- 1555 Views
Last post by RC10th
- 1391 Views
Last post by DaveM
- 2088 Views
Last post by XLR8
- 23 Replies
- 3123 Views
Last post by NickTheGreek
- 2279 Views
Last post by Synergy
Users browsing this forum: Semrush [Bot] and 4 guests
