Worlds wheels on an A stamp.
I put the worlds wheels 6805 rear, 9688 front on my A stamp this week.
I think the offset is a little tight in the rear
- Has thanked: 727 times
- Been thanked: 26 times
Re: Worlds wheels on an A stamp.
Hi,
Do you have any spacers on your axles if you do put all of them on the outside,
I think the new cva's axles are a little longer to take this spacer on
the outside.
http://www3.towerhobbies.com/cgi-bin/wti0001p?&I=LXEAD3&P=7
http://www3.towerhobbies.com/cgi-bin/wti0001p?&I=LXDWJD&P=7
Dave.
the outside.
Dave.
1/4" original stub axles..
Amazing what you can do with a 1/4" drill bit..
I'll check for spacers.. thanks.
Everything clears but you can't use the outer shock mount hole on the rear arms.
Hi,
Well there's your problem those wheels are designed to work with the two parts I gave you and
and these hubs.
http://www3.towerhobbies.com/cgi-bin/wti0001p?&I=LXEDZF&P=7
or the conversion kit,
http://www3.towerhobbies.com/cgi-bin/wti0001p?&I=LXDWJJ&P=7
Dave.
and these hubs.
Dave.
I"ll probably do the 6802 conversion kit.. thanks for the tip..
Will the 7364 white carriers work with that?
- Has thanked: 36 times
- Been thanked: 1318 times
the new worlds wheels have the same backspacing as an old tq wheel. so i really don't understand why there is such an offset issue on the back.
they don't really look like worlds wheels though......
- slotcarrod
- Been thanked: 45 times
He looks like he has B4 wheels on the car, he needs these: http://www3.towerhobbies.com/cgi-bin/wti0001p?&I=LXDWJL&P=M
Rod Littau
Damn you are right .. These are 9689 wheels..
I'll go back to my cave feeling stupid now lol.
I didn't glue them so nothing lost but $5..
I also have a full set of Jconcepts wheels in white I could use if I convert the stub axles to 3/16. I bet they are the wrong ones too..
I only paid $16 shipped for the ties and wheels so it's not all that bad.
Hi,
Yes 7364 white carriers will work.
Quote" A person who never made a mistake never tried something new!"
Mistakes aren't failures it's called experience!
Dave.
Dave.
- 1518 Views
Last post by yellowdatsun
- 1553 Views
Last post by RC10th
- 882 Views
Last post by sandkil
- 2259 Views
Last post by Synergy
- 23 Replies
- 3120 Views
Last post by NickTheGreek
- 1908 Views
Last post by Welshy40
- 990 Views
Last post by rctodd1624
- 1622 Views
Last post by Lonestar
