What exactly does 2.2" wheel mean? (Tires and wheels)
toybaron
Post by toybaron »
Sorry for what may be a question with an obvious answer. I'm just wading back in RC and determined to finish some restorations started years ago, and also to run some older cars I have.
I'm trying to understand the measurement standards for wheels and tires.
I'm not following the differences between 1.9", 2" 2.2" wheels and the tires that are meant to match. Meaning; what measurement does 2.2" represent on a wheel? I assume something related to diameter, but for example I have a set of old Duratrax aluminum rims where the header card indicates 1.9" (part n# DTXC4023) but the measured diameter of the outer lip on the rim is 2.3".
There's no measurement I have found that reads 1.9..
Thanks in advance.
RC10resto
Has thanked: 1441 times
Been thanked: 548 times
Re: What exactly does 2.2" wheel mean? (Tires and wheels)
Post by RC10resto »
Should be 1.9" where the bead of the tire seats into the wheel
Been thanked: 498 times
exactly. the flange or side of the wheel may be significantly wider than the tire bead ID. that is the guiding dimension.
Users browsing this forum: No User AvatarGoogle [Bot], No User AvatarTbot [Bot] and 7 guests
