Or perhaps someone has these lying around already
thanks
I have many panels and some partial panels with pieces too that should fit your needs. I have some 093”and .075” uni panels with (Iridium Rainbow) finish. It was used on HPI cars for exclusive sales to Europe and mainly Japan.
Well took a shot at a sheet of the Uni from Rockwest and while the quality is top notch...very solid and no defects...it's unfortunately not a good match for the old school graphite sheets.Phin wrote:.....
If you want just plain black Uni carbon fiber Rockwest Composites sells some cheap sheets:
http://www.rockwestcomposites.com/browse/carbon-fiber-plate/carbon-fiber-uni-plate
I can't vouch for the quality though since I never bought any sheets from them.
Yeah that thought occurred to me too. There's a pattern of lines in the gloss finish that make the sheet look a bit like a vinyl record. Dulling the shine a little to remove those lines would improve the look.harvey wrote:If your Rockwell sheet is to shiny, I think that's just the finnish of the resin, not the fibers. Maybe you could scuff it up somehow. Emery paper would leave scratches, but how about a light sand blast?
you could try steel wool. I've used steel wool to remove the shine off of powdercoating in the past to make it look like hard anno. Depending on how much elbow grease you apply it can degloss pretty quickly or slowly to get your desired results.Phin wrote:Yeah that thought occurred to me too. There's a pattern of lines in the gloss finish that make the sheet look a bit like a vinyl record. Dulling the shine a little to remove those lines would improve the look.harvey wrote:If your Rockwell sheet is to shiny, I think that's just the finnish of the resin, not the fibers. Maybe you could scuff it up somehow. Emery paper would leave scratches, but how about a light sand blast?
Don't know how much better it would match some of the old graphite though. I was hoping to use some of the material to recreate parts for a Woods pan car I own but that definitely won't happen even without the shine.![]()
Also I don't have a sandblaster, and it would be my first go at using one so I'm sure I'd just make things worse.![]()
