B2 question
General info, Q&A.
R Cane
Has thanked: 159 times
Been thanked: 64 times
B2 question
Post by R Cane »
When the early B2 switched from white to black servo parts, did the part number change? It's #9155 in the 1996 manual.
sandkil
Has thanked: 780 times
Been thanked: 584 times
Re: B2 question
Post by sandkil »
R Cane wrote:When the early B2 switched from white to black servo parts, did the part number change? It's #9155 in the 1996 manual.
Good one! Just looked at the rcca Dec. 1995 p. 85 issue and the "prototype" that Matt Francis drove which had the older stealth transmission had the black servo saver.
The white servo horn had same p/n 9180 as the newer black one.
slotcarrod
Been thanked: 45 times
Re: B2 question
Post by slotcarrod »
I'm sure the part numbers stayed the same. I have only seen the white bell cranks in two kits. I have never seen any white bell cranks with shelf tag. So I think they changed to the stronger black plastic right away, before parts got out to store shelves. The white servo arms and servo mount were also used on the early RC10GT btw.
R Cane
Re: B2 question
Post by R Cane »
ok, thanks!
