Rc10 stealth carpet set up
Trackingz
Post by Trackingz »
Looking for tips/set up to run a Rc10 stealth indoors on flat carpet, its a open buggy class at my local club they mainly run touring cars so no jumps :-(
Formerly known as veeza
JasonB
Re: Rc10 stealth carpet set up
Post by JasonB »
I ran a team car in "buggy" class on a flat carpet (tc) track years ago. Finding proper wheels and tires might be the biggest challenge unless you do the wheel conversion. They can do shockingly well with just a proper setup, but a lot of faster people changed parts and went to a zero kickup nose plate. You will need some stiff springs and heavy (40+) shock oil to begin with. The geometry gets funky when you lower it, so (now that they are available 3d printed) a lowering kit would be a good idea. Good luck!
twisted
Post by twisted »
look up Craig Dreschers set up.
Trackingz
Post by Trackingz »
Coool thank you for reply will have a look and try few set ups. I ran it last friday with yellow mini pins on the back and cut stagers on front silver springs back blue front 35wt oil heaviest i had, a lot of roll but worked well great involving buggy to drive :-)
JasonB
Post by JasonB »
If you can, get or make a flat nose with no kickup. An easy and cheap alternative that will get you part of the way there is the 15 degree caster blocks 6213.
I'd start the shock oil at 40 minimum. Limit down-travel and add some shock limiters, start around 4-5. Depends on how big of bumps (if any) you have on track. If it's super smooth surface you'll REALLY appreciate heavy oil and a tied-down suspension even in a vehicle designed for off-road bumps.
RC10th
Has thanked: 52 times
Been thanked: 1548 times
Post by RC10th »
Too low of a ride height hurts performance, arms level or a few mm below is all you need. If you want to lower the CG use smaller diameter tires if allowed like Custom Works or such. With suspension 5wt heavier and a spring rate or two heavier is also all you need. Too stiff and you start to take traction away. If the car wants to slide and becomes skatey it generally has too little droop and or is too stiff. The sweet spot is when the car rotates well from the corner entry to exit without oversteering or scrubbing too much corner speed.
Users browsing this forum: No User AvatarAmazon [Bot] and 2 guests
