RC10 Worlds Car - Carpet Setup
General info, Q&A.
My kid bought a worlds rere while we were up at the vonats. Now he wants to get into racing. So, our local track has an indoor carpet offroad track (not very big, tight corners). I'm looking for some assistance on a baseline setup. Oil, pistons, springs, tires, etc.
Any help would be appreciated. :)
Been thanked: 3919 times
Re: RC10 Worlds Car - Carpet Setup
scr8p wrote: .....Oil, pistons, springs, tires, etc.
I would recommend all of those items. Especially the shock oil, makes a huge difference.
I have nothing to offer except if you want a Mcallister lowering kit I'll mail it to ya :mrgreen:
:lol:
askbob
Post by askbob »
I raced my CE on carpet several times. Brown springs front, green rear. Will have to check oil specs. Rear axles level, front a tad high from level. Schumacher mini pins rear, cut staggers or mini pins in front. 3 degree rear arm mounts which I think someone revealed the stock rere worlds mounts are.
integra22t
Post by integra22t »
my andys set up was 30wt f 35w r silver springs 1/2" spacer on rear shocks none on front arms level
min pin on rear ribs on front
90/20 for 14d brushed motor
on this track
spru
Post by spru »
Hi scr8p,
take a look at this link http://www.petitrc.com/setup/associated/SetupSheetsAssociatedRC10WC.html
There is a nice setup for carpet from grand master Craig Drescher.
You can also start with silver front and rear springs, 40wt front with #2 pistons and 30 to 35wt in the rear with #1 pistons.
Front tower middle hole and outer hole on arms. rear tower second hole from inside and outer hole on arms.
Put the rear arm mounts backwards and you won`t need as much weight and blue springs in the front as Craig.
Greetings
Raimund
ok, thanks guys.
for the most part, i threw the drescher setup at it. so we'll see what happens. :wink:
spru
Post by spru »
Please let me know how it worked because I had no chance to test it on my own.
Have fun
Raimund
askbob
Post by askbob »
Curious to see how that setup would work too.
Any idea why the heavy springs, oil and all that weight?
slotcarrod
Been thanked: 45 times
Post by slotcarrod »
askbob wrote:Curious to see how that setup would work too.
With the higher traction of the carpet, you tend to chassis roll more than slide and stay flat. Also the carpet is smooth, so a softer setup is not needed.
Jay, I would also try a soft to mid tension rear sway bar.
