Lipos in a bosscat?
Lipos in a bosscat?
Anyone have any pics of lipos mounted in a bosscat? What did you use for straps/brackets etc?
Re: Lipos in a bosscat?
I use Core RC stick packs in mine, in some 3D printed saddles to lift it above belt.
http://www.tamiyaclub.com/showroom_model.asp?cid=126136&id=41229
Purple saddles are just about visible. I swapped velcro ties for releasable tie wraps, as pack moved otherwise.
- Groomi
I cut in half a cougar SV saddle lips cradle, used the existing forward position rear holes and drilled new front holes in the Bosscat chassis. I found the weight to be too forward bias, so will be moving them back and at an angle so the new front hole goes inwards of the cutouts.
Will try to find a pic...
Saddles available from Shapeways,
https://www.shapeways.com/product/QLBM9M94M/schumacher-bosscat-stick-pack-saddle?li=user-profile&optionId=56032112
- 20 Replies
- 3383 Views
Last post by Mark Westerfield
- 584 Views
Last post by klavy69
- 1848 Views
Last post by DrumAnBass
- 1089 Views
Last post by Erich Reichert
- 548 Views
Last post by shane
- 1032 Views
Last post by iPearl
- 21 Replies
- 2604 Views
Last post by Lonestar
- 1178 Views
Last post by hawgfanman
