Ballancing lipos
Ballancing lipos
I was thinking of upgrading to lipo batteries and have a charger capable of charging them( duratrax onyx 230). It does not ballance them. Do lipos have to be ballanced or can you run them without doing so? What are the advantages to ballancing? What can I do to ballance them without buying a new charger? Sorry for all the questions but when I used to race my rc10 before, all we han were 1200 mAh packs
- Has thanked: 36 times
- Been thanked: 1338 times
Re: Ballancing lipos
Regardless of what you might have heard LiPo's need to be balanced at least every other charge. Get a balancer like this one LBA10 balancer and you'll be set. That balancer will allow you to balance while charging or balance as a stand alone unit.
- Eau Rouge
- Been thanked: 5 times
That's a new one...Daddeo wrote:Regardless of what you might have heard LiPo's need to be balanced at least every other charge.
Based on information from whom?
- Been thanked: 12 times
Lipo care is getting to be almost as religous a topic as nicd used to be.Eau Rouge wrote:That's a new one...Daddeo wrote:Regardless of what you might have heard LiPo's need to be balanced at least every other charge.
I ran a lipo pack many times in a non-lipo cutoff basher, stopping only when the truck slowed. and never balance charged. I charge at about 1.5C and the pack still works great. When I checked the cells with a dvm while charging they were very close to each other. I have since gotten a balancer that I occasionally use(mostly out of fear from so many people claiming you "have to"), but most often charge without it.
- Eau Rouge
aconsola wrote:Lipo care is getting to be almost as religous a topic as nicd used to be.
That was bound to happen sooner or later. Plenty of people that need to spend money on stuff they don't need.
Not a new one at all. The cells in a pack can become unbalanced over time thus creating a potential situation for one of the cells to go below the safe voltage limit. By keeping a semi scheduled routine of balancing them prevents this from happening (assuming all other precautions are being taken) and you not having to trash expensive batteries. When I first started using LiPo's I agreed with the notion of not having to balance them. A few months after purchasing a expensive LiPo I started to notice a drop in performance. Of course these were the days when I did not believe in balancing LiPo cells on a regular basis and checked each cells voltage. I found that one of the cells had in fact gone bad due to not being balanced. $150+ down the drain but I did salvage the remaining good cells, although that's not what I paid for in the first placeEau Rouge wrote:
That's a new one...
Just trying to help a fellow hobbyist out and possibly keep them from having the same aggravation.
Get a hyperion charger, mine can do nicd, NiMH and Lipo's, I do you an external common sense charger. I balance mine everytime, I must be an idiot but my packs have never "poofed" like a couple others I know. Ironically they were the ones that told me I didn't need to balance everytime
- Erich Reichert
That little Trakpower charger and balancer I have is pretty nice and I dn't think they're that expensive either... and their GOLD!
- 20 Replies
- 3401 Views
Last post by Mark Westerfield
- 1871 Views
Last post by DrumAnBass
- 595 Views
Last post by klavy69
- 1496 Views
Last post by THEYTOOKMYTHUMB
- 20 Replies
- 5058 Views
Last post by RCveteran
- 80 Replies
- 11110 Views
Last post by Diamond Dave
- 1758 Views
Last post by Danf1275
- 1186 Views
Last post by hawgfanman
