compatible diff with YR4-M2?
proffesso
Post by proffesso »
pulled apart a diff from a YR4M2 only to find its rusted to hell. are there any compatible diffs out there that will fit?
cheers
I'm a retro radio control hipster - I only like the stuff no one bought!
aip47-2008
Has thanked: 170 times
Been thanked: 23 times
Re: compatible diff with YR4-M2?
Post by aip47-2008 »
proffesso wrote:pulled apart a diff from a YR4M2 only to find its rusted to hell. are there any compatible diffs out there that will fit?
cheers
ZD-500 is the part number for the YR4M2 version.
Asso_man!
Has thanked: 40 times
Been thanked: 82 times
Post by Asso_man! »
You'd be surprised how you can get some badly rusted parts back to life. Try to soak it in WD40 overnight, then wipe it gently and use a steel wool pad to clean it.
Come and visit the stable
Return to “Yokomo Forum”
