I lucked out and got this in a trade. Plans are to make it a decent runner first. I'm not sure if I will turn it into the car I raced in the late 80's early 90's or if I will just do some upgrades if the car breaks. First thing is to get a new body and figure out what I need to do to convert it to modern wheels and tires. I'm not sure about the wheels that are on it, they look like Dhawk but the set I saw seemed way too expensive for this car. On to the pics.
I imagine the bottom of the car was saved due to the crazy amount of preload
New to me CE/ build thread
- Bottom Feeder
- Has thanked: 10 times
- Been thanked: 23 times
Re: New to me Championship edition
Rear arm mounts are on backwards, like usual. Doesn't anyone pay attention to the directions? Drives me nuts!
(Not directed at you, OP. I know this car is new to you, just venting.)
Ha thanks for pointing that out. I will handle that when I pull it all apart to clean and see whats what.
Alright I think I am going to build it WOIN. I've cleaned up the chassis, installed the rear mounts correctly and sorted through what I think it will need. I have read a million threads and think I have a good idea of what I am doing. I changed to worlds steering, I need to order bearings though. I got B4 front wheels, I thought my stock rear would work. They don't p.o. has 3/16 stub axles in there (no spacers at all ). I installed the 10GT steering blocks and axles. So I need rear wheels and tires all around, I think I need carbon works shock towers. 1.18 rear shocks with 1.02 fronts, B4 top shaft and slipper. I don't know if the klein arms are a lot wider than what I have or if I need a 10T front to use them. I also painted a body, it's been a long time since I have done that.
- 100 Replies
- 15528 Views
Last post by DerbyDan
- 19 Replies
- 3101 Views
Last post by zuki250
- 578 Views
Last post by besty22
- 75 Replies
- 10717 Views
Last post by Asso_man!
- 599 Views
Last post by SoAzRC
- 31 Replies
- 6133 Views
Last post by isles1
- 46 Replies
- 6040 Views
Last post by surgetek
- 40 Replies
- 6037 Views
Users browsing this forum: Bing [Bot], Facebook [Bot], Google [Bot], Google Adsense [Bot] and 38 guests
