Need Help Picking an ESC & Motor
Any suggestions on what kind of ESC Motor combo I should be running for my RC10 DS?
As of now, I am looking for brushless and non-censored. I will not be competing, will be running on asphalt and plan on using a LiPo battery.
Here is what I am looking at so far:
Associated XP SC700-BL/Reedy 540-SL 3900kV Combo
http://www3.towerhobbies.com/cgi-bin/wti0001p?&I=LXCACB&P=7
Castle Creations 1/10 SV3 Sidewinder SCT System 3800kV
http://www3.towerhobbies.com/cgi-bin/wti0095p?FVPROFIL=&FVSEARCH=lxdrln
Castle Creations 1/10 Mamba Max Pro SCT 2400kV System
http://www3.towerhobbies.com/cgi-bin/wti0095p?FVPROFIL=&FVSEARCH=lxaetu
- DMAT
- Been thanked: 4 times
Re: Need Help Picking an ESC & Motor
the MMP combo is total overkill. im not sure it would fit in the car too.
I have the Sidewinder 3800 combo in one of my buggies and its a lot of power for the car. Its a good bang for buck combo but dont expect to use the motor fan w/o cutting away a large chunk of the motor plate.
no real opinion on the xp/reedy system.
I am new to this so bare with me.DMAT wrote:the MMP combo is total overkill. im not sure it would fit in the car too.
Doesn't the higher "KV" equate to more power?
- slotcarrod
- Been thanked: 45 times
KV is the RPM per each volt. So a 3000kv motor "roughly" equates to 3000 rpm per volt.
Rod Littau
- RC104ever
I have used all of these combos in one of my RC vehicles over the years. Here's my take - the XP is just 'okay'. While it seems to be a bit smoother in operation than the Castle systems, its no where near as flexible or programmable.
Now, if that isn't important to you, then get that system.
If it is, then you should look at one of the Castle systems. But the 3800 and 2400 are designed more for torque than speed. I would suggest a 4600 motor as that would be LOTS of power for the DS. I'm running a 4600 in my T4 and it just flies and still has tons of torque for off roading. I also run a 5700 in my RC10 buggy but its bordering on overkill. Depends on your gearing and the battery you are using too.
- Chris
Lots of cars...so many cars
Thanks guys for clearing that up for me.
I spoke to someone at Team Associate and they told me that a DS could not handle anything over 3900kv.
It's reassuring to hear that other are running faster motors in similar cars.
Not restricting my criteria to under 3900kv opens up many more options!
- RC104ever
I'm not familiar with the DS but isn't it essentially the same as the RC10 buggy except its an onroad car? If it has the same stealth tranny then there is nothing to worry about power wise - you can put a huge motor on it, just need to gear it correctly.
- Chris
- DMAT
I would think thats about right. I would think putting the 3800 motor in the rc10 is about the same to putting a 1/8 system into a rustler like so many others have. I wanted to suggest the 4600 motor but i felt at odds about it. on 2S that car will fly.
All of those choices are way too much power. You're going to have a hard time keeping the diff alive with them. I would suggest you look at the Hobbywing Just Stock Club Spec ESC (Sensored for $50) and a Trackstar 17.5 motor ($35).
RC10 Short Arm | Novak Tempest ESC | Tamiya Torque Tuned 25T | Savox 1258 | Stealth Trans w/ Exotek Slipper Eliminator (geared 24/81)
RC10B3 | HW Just Stock Club Spec | Reedy 13.5 | Savox 1258
- Been thanked: 325 times
I kind of agree with ca-rj, but I would suggest a motor that's no lower than 13.5T without a lot of attention paid to bulletproofing the drivetrain. 17.5T might be erring too much on the safe side.
- slotcarrod
The Stealth can handle just about any motor, if built correctly! Even though your DS may or may not have a slipper, a slipper would be best for anything lower than a 8.5 or 8. Nothing in that list is too much for a Stealth using a 7.4 volt lipo. 11.1 may be another thing if you like to punch the gas or do donuts!
Rod Littau
What do you mean "build correctly'? Does a stealth need to be upgraded?slotcarrod wrote:The Stealth can handle just about any motor, if built correctly! Even though your DS may or may not have a slipper, a slipper would be best for anything lower than a 8.5 or 8. Nothing in that list is too much for a Stealth using a 7.4 volt lipo. 11.1 may be another thing if you like to punch the gas or do donuts!
- RC104ever
No he means that you have to make sure that its built to the exact specs that are in the instructions.
- Chris
This is a good guide for building a stealth tranny: http://www.rc10talk.com/viewtopic.php?f=7&t=3721RC104ever wrote:No he means that you have to make sure that its built to the exact specs that are in the instructions.
my thoughts exactly. a stealth can handle anything you throw at it, provided it's maintained and built well.slotcarrod wrote:The Stealth can handle just about any motor, if built correctly! Even though your DS may or may not have a slipper, a slipper would be best for anything lower than a 8.5 or 8. Nothing in that list is too much for a Stealth using a 7.4 volt lipo. 11.1 may be another thing if you like to punch the gas or do donuts!
b4 top shaft and slipper and it will take anything a b4 will.
I can say that I have never worried about one of these tranny's letting me down.ever.
- 2050 Views
Last post by uniquenamehere
- 2599 Views
Last post by abailey21
- 1253 Views
Last post by bully
- 1985 Views
Last post by Lonestar
- 2260 Views
Last post by longboardnj
- 644 Views
- 1228 Views
Last post by juicedcoupe
- 4382 Views
Last post by joey_zrl
