Question about an Ultima "Belt-Drive" Conversion
- drbelleville
- Been thanked: 4 times
I have a friend overseas (Germany) who is inquiring about a belt-drive conversion, that may have possibly included a slipper for the Ultima series? He is trying to build a car up, and althought the going is slow, he has a few questions. Any help is greatly appreciated.
- highwayracer
- Been thanked: 6 times
Re: Question about an Ultima "Belt-Drive" Conversion
I think there are 3 options:
Lethal Weapon made by A&L. This has the ball diff and the slipper. Good transmission, but very difficult to find.
kyosho Triumph. The triumph transmission bolts into the ultima with little to no modification. It's become a nice option since the A&L is difficult to find. It has a ball diff and a slipper. The kyosho slipper is a little bit different because of the type of spring washer used on the clutch.
Track Master - This is ok, but the center (diff, belt and cog) is exposed because it uses 2 side plates. Aslo, I don't think these came with slipper clutches. You can probably adapt on to it, but I've never done that.
- drbelleville
Thanks for the reply, this should help out. So I guess its better to look for the later model Kyosho Gearbox then instead of the A&L.
- highwayracer
The cool factor tells me to go for the A&L, but more triumphs (and spares) were made. So if something went wrong with the A&L, it would be more difficult to find spares (in theory).drbelleville wrote:Thanks for the reply, this should help out. So I guess its better to look for the later model Kyosho Gearbox then instead of the A&L.
- drbelleville
I guess the A&L would be good for a shelfer then.
- Mr. ED
- Has thanked: 62 times
- Been thanked: 62 times
And daryl lane is a member here (the L in A&L) and stil has some private stock. So if you're ready to pay the price it's not tall that difficult to get.
- transamman908
- Been thanked: 5 times
Team Pit Stop made a chain drive transmission for the Ultima.
- LTO_Dave
- Has thanked: 52 times
- Been thanked: 287 times
TPS also made an optional slipper.transamman908 wrote:Team Pit Stop made a chain drive transmission for the Ultima.
Bullet(sp) Racing also made an enclosed belt-drive tranny for the RC10...not sure about one for the Ultima, though.
And don't forget about the HyperDrive system that used a belt in place of the spur and pinion. May have rigged up a slipper with the belt system?
- drbelleville
there is also a hyperdrive belt conversion .
2nd place is just the 1st loser
- 1750 Views
- 791 Views
Last post by dinglem
- 33 Replies
- 4160 Views
Last post by terry.sc
- 1587 Views
Last post by magic
- 2050 Views
Last post by RCveteran
- 21 Replies
- 3731 Views
Last post by a01butal
- 31 Replies
- 6035 Views
Last post by cas22
- 43 Replies
- 11009 Views
Last post by klavy69
