Original style F.H.M.S. hardware?
General info, Q&A.
RC10th
Has thanked: 52 times
Been thanked: 1548 times
Post by RC10th »
Anyone have a source for original style 8-32 screws, or a large stash? I know this has been discussed elseware but couldn't find it. After snapping the head off of a worlds re-re screw I cant risk the unreliability. Are there any sources for original type hardware like the old goldish/green colored screws. I see AE has two different part numbers listed for the screws, I've bough both part numbers before to figure out which but I've since used them and can't remember.
I have a couple packs of I think Yokomo 8-32 steel screws that I can use but rather stay OEM if I can.
DaveM
Has thanked: 727 times
Been thanked: 26 times
Re: Original style F.H.M.S. hardware?
Post by DaveM »
Hi RJ,
Do you have the two different part numbers for the screws?
Dave. :)
RC10th
Post by RC10th »
I'll have to google it again.
One looked like the cheap off center stamped screws that come with the worlds cars. (16 in a pack maybe)
The others look much better, lighter in color, screw stampings are centered and the screws look anodized. 6 - 10 in a pack if I remember?
DaveM
Post by DaveM »
Hi RJ,
Looks like I have one part # for you,
I have 6280 8-32 x 1/2, 16 of them.
First one I took a look at, the screw stamping is off center.
Second one the same.
Dave. :)
bully
Been thanked: 6 times
Post by bully »
I recently ordered both because I wanted the original style but unfortunately they are all the same now,I ordered both from tower... The other part number is ASC3324 for the half inch size along with the 6280 in the same size.. Unless you can see and touch them before you buy count on getting the new inferior type unfortunately.. If you search local shops near you maybe you will get lucky and find some of the old ones
harvey
Post by harvey »
That's interesting; I hadn't heard that the 'new' screws were inferior. I like the new dark olive colour, but if they break, that's no good. Has anyone busted the blue FT screws on the track? I have found that they are much fatter at the head and don't sit flush in most chassis without additional countersink. I have stripped the blue off of all mine!
Users browsing this forum: No User AvatarGoogle Adsense [Bot] and 3 guests
