I think it would be safe to say most of us are hoarders to some degree, so, what do you do with your left over scratched and rusted hardware?
Do you save all of it, throw it all away, or pick out the salvagable bits and turf the rest?
Personally I pick through and keep what is salvagable, I used to throw away rusty parts but have since learned that oxalic acid eats rust and leaves you with a clean part. I should have hung onto them in that case but didn't, how many turnbuckles, screws, axles and ball ends went in the bin that could have been given new life. Scratched screws on the other hand, pretty difficult to save. I guess you could recondition the heads and replate them, plus I've found that early AE hardware was much better than later.
What do you do?
What do you do with your old hardware?
- RC10th
- Has thanked: 52 times
- Been thanked: 1548 times
- Has thanked: 1129 times
- Been thanked: 3919 times
Re: What do you do with your old hardware?
Although I have some barkeepers friend here, and thats the main ingredient. might have to see how it handles rust. Just add water? Hmmm
- Has thanked: 11 times
- Been thanked: 6 times
i used to throw all mine away. I kind of regret it, because i could use a lot of what i had thrown away. What I've been doing is buying screw kits off Ebay or Tower Hobbies for certain rebuilds, and save the old screws and hardware. The old screws and hardware are real handy for them basher builds.
- Been thanked: 325 times
If it's stripped out--screw heads and plastic/alloy parts with threads damaged--I make sure to throw it out, because I don't want to use one of those in the future, and I wouldn't want to sell them to someone, either. I keep anything else as long as it's not rusted out or obviously damaged, because I know I won't use those items in any of my builds. I find that I'm always finding uses for old parts, and often it's not the intended use.
- 1083 Views
- 1059 Views
Last post by Michaels tc
- 786 Views
Last post by sk7
- 2130 Views
Last post by bearrickster
- 1939 Views
Last post by NomadRacer
- 1039 Views
Last post by harvey
- 409 Views
Last post by Dbrite111
- 1427 Views
Users browsing this forum: Amazon [Bot] and 3 guests
