anyone ever thought of this?
- Regular Member
So i have been lurking around on the forums for a litlle while, and i have been wondering if anyone has ever tried to create/ modify a car to be a 6 wheel drive? i know there are already 6x6's but i was talking about making a track car and not a crawler lol.
- DMAT
- Been thanked: 4 times
Re: anyone ever thought of this?
anything is possible if you try. you'd might need a custom cut chassis and modifying a few other parts but I dont think it would be that hard. pick an end and go with.
- Lowgear
- Has thanked: 121 times
- Been thanked: 795 times
^That's only 4wd but the same concept. Take multiples of the same vehicle, cut them up, then just figure out a way to attach them together and voilà!
- integra22t
- Has thanked: 25 times
- Been thanked: 143 times
here is mine http://www.tamiyaclub.com/pictureframe.asp?t=n&id=img7734_18042006235158_2.jpg it ran pretty good but was very heavy. sold it like 2 years ago.
- Been thanked: 325 times
I've considered doing something similar with an Optima chassis; the 4 rear wheels would be 4WD, using the normal Optima's front & rear diffs to drive them, and the fronts would be non-driven...so it would only have been 4WD, not 6WD. There's already lots of cars out there like that, so I wouldn't have been doing anything unique, and it would've been too much complicated work figuring out how to drive the 2 fronts, so I never went through with it.
Yes, that would certainly work! I've never had any Maxxum parts, though. Never gave it a serious thought.Phin wrote:A 6wd Optima wouldn't be too hard if you don't mind using two motors. You could power the front wheels using a Maxxum FF transmission.
- terry.sc
- Has thanked: 7 times
- Been thanked: 157 times
A 6WD Optima wouldn't be too difficult, the front diff case has two sprockets on it so the centre diff could be used to drive the front diff as well.
Everybody says it's easy...but I've never seen it done.
I put a lot of thought into it years ago and abandoned the idea because I doubt it's as easy as everyone says.
Somebody feel free to prove me wrong.
- Phin
- Has thanked: 87 times
- Been thanked: 248 times
You could also use that double sprocket to run the middle pair of wheels in a Slingshot type setup and then run another chain off it to the rear set of wheels.
- Diamond Dave
- Has thanked: 699 times
- Been thanked: 130 times
Awesome thread!Phin wrote:Daryl Lane's 4x6 - http://www.rc10talk.com/viewtopic.php?f=77&t=22221#p327710
I've toyed with the idea of using lazer zx-5 gearboxes cut in half and two fronts grafted together so you would have an input shaft and an output shaft to drive another gearbox. The only real problem i can see is that the zx-5 gears are not that beeffy and would most likely strip the bevel gear in the first gearbox.
- 941 Views
Last post by tudor39
- 52 Replies
- 4300 Views
Last post by Tadracket
- 2381 Views
Last post by radioactivity
- 1145 Views
Last post by SteveK
- 29 Replies
- 1638 Views
Last post by rc10johnny
- 1455 Views
Last post by Diggley
- 630 Views
Last post by Bongo Fury
- 1746 Views
Last post by mrlexan
Mojeek [Bot] and 6 guests
