Custom Works Enforcer 10
- Brandon G
Got this recently off the bay. I have been looking for an old school sprinter to add to my collection... Finally found one for what I thought was reasonable.
Came with all vintage electronics, Novak M something esc, 2 new Reedy Sonic mod motors, a Tekin receiver, Sanyo battery pack, plus lots of tires and parts.
As much as I like the thought of keeping this car new and unused, I plan on running this locally. Can't see spending $400+ for a "newer" version of this car when this will do the job. I will have to do some axle converting in the rear to allow the use of B4 wheels, but that aint anything new...
- Mr. ED
- Has thanked: 62 times
- Been thanked: 62 times
Re: Custom Works Eliminator 10
very clean and good-looking. Why do you want to convert the wheels?
If you got a couple tires and wheels with the car, just run these for some time.
Is this the car with the sliding steering components?
- Brandon G
They are the 2.1" rears that were included. I've used 2.2" tires on these wheels once before but didn't like how it turned out. Unfortunately, none of the rubber that came with it would be too effective on the track I will be running at.
And yes, it does have the sliding steering section. Interesting.
- Mr. ED
I've been wanting to get that steering setup for a trial on some concept cars. Someone here proposed the idea, but I've been checking regularly on their site and it allways shows as out of stock
- Has thanked: 36 times
- Been thanked: 1318 times
http://www3.towerhobbies.com/cgi-bin/wti0001p?&I=LXNTD1&P=SM
nice Enforcer 10 you got there, brandon.
- Mr. ED
Thanks!!! I've added it to my whishlist, and when I finally have a new job I'll put in the order for all those little things collected in it. there's sooo much little stuff on their site I have ideas forscr8p wrote:http://www3.towerhobbies.com/cgi-bin/wti0001p?&I=LXNTD1&P=SM
- Brandon G
Correct you are scr8p. I will fix it!scr8p wrote:http://www3.towerhobbies.com/cgi-bin/wti0001p?&I=LXNTD1&P=SM
Re: Custom Works Enforcer 10
you must've had bolink on your mind.
have fun with it. sprinters are a blast to drive. especially wingless.
- Charlie don't surf
- Has thanked: 355 times
- Been thanked: 470 times
Brandon, any chance you want to sell those front Proline wide 5 front tires? LMK
Reggie
Reggie
- Brandon G
Work has finally begun on this car!
I have done the rear arm conversion similar to my '91 worlds car. RPM RC10GT rear hubs, Dynotech "Klein" rear arms, MIP B4 CVD's.
The front has been widened with the Dynotech wide Enforcer 10 arms.
Running B4 wheels front and rear.
Waiting to paint my 7"X7" Custom works top wing.
Novak GTB and 13.5 BL motor is on the way...
- Mr. ED
been holding my laptop in different angles but can't get a clear view on that steering system
the custom works slider bellcrank.Mr. ED wrote:been holding my laptop in different angles but can't get a clear view on that steering system
- Mr. ED
- 38 Replies
- 7312 Views
Last post by dillonhoffman
- 1642 Views
Last post by a01butal
- 1829 Views
- 2356 Views
Last post by nikos2002
- 1025 Views
Last post by mytimac
- 3308 Views
- 2009 Views
Last post by dldiaz
- 3272 Views
Last post by SLIDER
