YZ 10 alloy wing mounts
I need some alloy wing mounts (the bit that bolts to the shock tower) for my YZ 10 project, and I'm starting to think they might be a bit rare!
I may resort to making some reproductions, so need the dimensions.
Would someone be kind enough to measure one up for me?
Length and diameter would probably suffice.
It looks like they are probably a full radius on the end, is that right?
- Incredible_Serious
- Has thanked: 1737 times
- Been thanked: 1145 times
Re: YZ 10 alloy wing mounts
Do you have a photo? I'm not a Yokomo expert, but I do have a couple of different alloy wing mounts kicking about.... I was just going to use them on a Mini Mustang project!npdp72 wrote:I need some alloy wing mounts (the bit that bolts to the shock tower) for my YZ 10 project, and I'm starting to think they might be a bit rare!
The pictures here show the alloy wing mounts pretty clearly.
http://bloodclod.blogspot.co.uk/2010/11/yz-870c-update-lipo-trays-body-shell.html
Let me know if you can help.
Thanks.
Thanks.
I'm going to look today, but those do look familiar.....npdp72 wrote:The pictures here show the alloy wing mounts pretty clearly.
Thanks.
wing mounts for 870C are as follows(look like the ones in the link above).
overall length, 16mm
8mm OD
thread on flat end is M3 for mounting to tower
set screw is M3, located at 11mm from mounting face of shock tower.
wire hole is ~2mm, this can be really whatever you want.
the rounded 'bullet' section of the mount is approx 2.25mm long from the end of the mount to the end of the 'round'. essentially has a 4mm radius, nearest I can tell. as long as you put some kind of rounding on the end, no-one would ever know without measuring. The pair I have aren't really machined perfectly, so whatever you get, is probably good enough.
hope that helps.
8mm OD
hope that helps.
Nigel,
I've used A&L mounts, they aren't identical but do the same job and work well:
http://vintageteamaandl.com/
Click on the section named 'universal'
Dan
Dan
- Been thanked: 10 times
i have those nip .....if you want to go with the original stuff .....
otherwose i would go to A&L
mvh isobarik
mvh isobarik
I've found one!
So if anyone else has an odd one lying around let me know please!
- Has thanked: 178 times
- Been thanked: 155 times
Aren't they making reproduction units in that '91 Worlds Stealth car kit?
Thought I saw them and meant go buy a set.
Losi LXT (JRX-T Conversion)
Losi JRX Pro SE
Kyosho Rocky
Parts-Car-to-Runner Kyosho Rocky
Yokomo YZ10 WCS '95 Pavidis
RJ Speed Spec10 "Chew Toy Mk1"
Redcat Lightning STK "Chew Toy Mk 2"
Kyosho Lazer ZX, ZX-R, ZX-RR
Losi JRX Pro SE
Kyosho Rocky
- Has thanked: 36 times
- Been thanked: 1318 times
Yes, Jake is reproducing them. They're around $200 per pair, but you do get some cool extras with them.
Oh, is he selling those only as part of the kit?
Losi JRX Pro SE
Kyosho Rocky
Losi JRX Pro SE
Kyosho Rocky
- Has thanked: 1129 times
- Been thanked: 3919 times
- a01butal
- Has thanked: 34 times
- Been thanked: 40 times
Antonia has then NIP but a little pricey.
http://www.ebay.com/itm/4933-50m-Graupner-Yokomo-Dog-Fighter-Spoiler-Halter-NEU-/321582751814?pt=RC_Modellbau&hash=item4adfd36046
This is all very interesting!
No luck in finding any myself... found all sorts of other types, just not that one.
Sorry....
Sorry....
How much interest would there be if I were to get a batch of repro ones made?
- 572 Views
- 2072 Views
Last post by mk-Zero
- 964 Views
Last post by Boredome
- 526 Views
Last post by 1300GT
- 2270 Views
Last post by drbelleville
- 655 Views
Last post by upforit365
- 1065 Views
Last post by RichieRich
- 858 Views
Last post by slow_jun
