Asr09's Worlds Re Re Racer
Asr09
Post by Asr09 »
GodSpeed
Re: Asr09's Worlds Re Re Racer
Post by GodSpeed »
A lot of nice things going on there.
Asr09
Post by Asr09 »
Here's the setup details:
Novak Edge 10.5 system
JConcepts steering and motor plate
Lunsford turnbuckles with TC6 turnbuckle eyelets (ASC31305)
RPM rear arms and gear cover
Futaba S9551 servo and R204GF-E receiver
I tried to go with as many black plastic parts as I could find. I plan to dye the bulkhead and tranny case.
I machined the brass weight myself. It's approximately 38g (1 3/8oz). Time will tell if it hurts or helps.
pumpkinfish
Post by pumpkinfish »
Did you use the kit ball studs with the TC6 turnbuckle eyelets (ASC31305)?
Asr09
Post by Asr09 »
Most of the ball studs are from the kit, but I used a few of the broached studs (used on the B4) here and there. I measured the difference between the two, and found it to be about .001" with the kit studs being slightly smaller.
Closeup of the front end:
