GPM STEERING ASSEMBLY INSTALLATION?!
Rc10boi
Post by Rc10boi »
Has anyone purchased and installed a steering assembly from GPM?? Having trouble with the install. GPM parts don't look like the stock ones. :?:
romulus22
Has thanked: 900 times
Been thanked: 789 times
Re: GPM STEERING ASSEMBLY INSTALLATION?!
Post by romulus22 »
Pictures of what you have? I can only find the steering for a GT, and they look the same as stock only alum.
Rc10boi
Post by Rc10boi »
romulus22
Post by romulus22 »
Not sure what the two posts on the bottom are for. But the it should install fairly similar.
Install the bushing in the top and bottom of the arms. Slide them over the two flanges post with the flange on the bottom. Then bolt to the chassis as normal.
Rc10boi
Post by Rc10boi »
Ok but what about the spring and lock above the servo arm? It adjusts the tension on the servo arm
Please look at # 4 on the instructions manual. That's what I have.
http://www.teamassociated.com/pdf/cars_and_trucks/RC10GT/7532.pdf
romulus22
Post by romulus22 »
That serves as a servo saver function. The GPM unit is fixed and you would need to run a servo saver on your servo if you still wanted to run one.
romulus22
Post by romulus22 »
If you're doing any sort of hard driving especially with a plastic gear servo you would need one of these.
http://www.rcplanet.com/Kimbrough_Servo_Saver_p/kim113.htm?gclid=CPCZstbPr8ACFcI-MgodSQwAlg
Rc10boi
Post by Rc10boi »
Sorry for the late reply but thank you for your help. I'll visit my hobby store and get one of those servo savers! :D
Bholzz
Post by Bholzz »
Bringing this back from the dead. Since this thread is so old, I believe I may have the same parts? I can’t find anything online about this part. GPM RGT048 Alloy Bearing Steering Assembly, which came new in package with a used rc10gt blue chassis that I got. There are no instructions online, and can’t figure out what the two larger standoffs are for, and they don’t fit anything. Anyone have a photo of this installed??
Return to “RC10 Truck Forum”
Users browsing this forum: No registered users and 16 guests
