I am looking for the distance from one side outer hinge pin to the other side outer hinge pin.
If that is too hard, we could go to the center of the chassis and double it
Perfect, that will do! I'm on B44 for now, not sure what the .2 and .3 added. I should probably look into that!transamman908 wrote:On my b44.2 it is 7 5/8" center to center if this is the measurement you need. I cut an inch on the ruler. Don't know if the b44 and b44.2 are different but I don't think so.
