Losi Junior X2 5-Link Hybrid
LosiXXkid
Post by LosiXXkid »
In line with my observation that things are a little quiet at the moment, I thought I'd share some photo's of my Losi Junior/ X2 5-Link hybrid. I've had most of these parts for a while so I decided to do something with them (even though I haven't finished a couple of other projects yet.... :oops: ).
I think the goal of this right now is for it to be a runner fitted out with some modern electrics.....not sure how long it's going to take as I sold off the vast majority of my RC gear many years ago :(
DerbyDan
Been thanked: 19 times
Re: Losi Junior X2 5-Link Hybrid
Post by DerbyDan »
Looks great.... all the parts look new!
Have I inspired you to build a runner with the photos of my cars from the weekend? I must admit it was interesting running the JRX2 back-to-back with the XX.... the XX really feels more resolved, the suspension soaking up all the bumps making it more compliant & easier to drive, yet at the same time it turned better & hence more nimble... the JRX2 has so much traction & despite being SWB understeers more, you can also sense the 'spring' from the flat graphite chassis which seems to make it less consistant? That said I probably enjoyed running the X2 more?
With the above in mind it makes me wonder how a 5-link car on a moulded chassis will handle? ....Quite nicely I would imagine! Swept front wishbones should help keep the understeer in check too! 8)
Jirka
Has thanked: 33 times
Been thanked: 24 times
Post by Jirka »
This is going to nice when done. LRM case from same material as Retrofit transmission (and XX proto transmissions, see 1993 worlds and Joel's car) is cool.
Jirka
LosiXXkid
Post by LosiXXkid »
DerbyDan wrote:Looks great.... all the parts look new!
Dan,
All the parts are new!
Yes.....! I'm pretty sure your entire thread was the inspiration for this build which has been ongoing for some time while searching out and collecting all the necessary parts. I'm waiting on a shipment from the USA which includes the suspension links for the other side.
The gear box outdrives are from the LXT sliders, the outdrive gears are the nylon machined ones from Thorp, the three diff gears are the aluminium ones from Thorp, the thrust assembly is the HD version from MIP (uses 3/32 carbide balls). The top shaft pinion is the nylon machined one from Thorp (which needed modifying as you discovered), and the diff uses dual 1/8" bearings. The slipper clutch will be the Team Associated VTS version. Basically I want the transmission to be as bullet proof as possible but it hasn't been cheap!
I'm also looking at making some repro shock towers from 3mm black G10/ FR4 as the original ones are hard to come by and flex just a bit too much...IMO.
On a side note, one of my colleagues has offered to produce some drawings of the original shock towers which could then be sent to one of our suppliers to have them machine cut. Depending on the cost involved, I may look at having a limited run produced but for now I'm going to make a set by hand....
FasterLouder
Has thanked: 13 times
Been thanked: 59 times
Post by FasterLouder »
The 5 link mounts on the Junior chassis are there for a reason!
Killer.
All The Way Alive
LosiXXkid
Post by LosiXXkid »
One more piece of the puzzle that I feel extremely lucky to have bagged!
Losi A-5001 NIP
Losi A-5001 007c.jpg (113.75 KiB) Viewed 3123 times
Losi A-5001 NIP
Losi A-5001 NIP
Losi A-5001 No longer NIP!
Losi A-5001 013c.jpg (123.82 KiB) Viewed 3123 times
Early thin black shock collars, original X2 shock cartridges, 5-Link lower shock mounts and the original upper shock mounts!
Sometimes lady-luck just happens to be lookin' out for ya!
DerbyDan
Post by DerbyDan »
Its the thin collers that are so rare! - Lucky sod lol!
I wouldn't even attempt to build your shocks with those cartridges - unless you are building them dry for show purposes!... They leaked Bitd - I doubt they'd be any better today!
LosiXXkid
Post by LosiXXkid »
DerbyDan wrote:Its the thin collers that are so rare! - Lucky sod lol!
I'm not going to use the original shock cartridges for that very reason! I might put them in the BST though as someone may want them for a shelfer or resto project...
LosiXXkid
Post by LosiXXkid »
Well, time for brief update. The drawing is done so this is going to happen...
Losi JRX2 Rear Shock Tower
oldrc
Post by oldrc »
Looks really nice, what is the benefit of the 5 link over h-arms?
I am not affiliated with oldrc.com, I'm just old when it comes to my RC history :D
DerbyDan
Post by DerbyDan »
oldrc wrote:Looks really nice, what is the benefit of the 5 link over h-arms?
The 5-link gives you loads of rear end traction - especially in loose/low grip conditions compares with a more conventional H-Arm set-up... unfortunately this also means a 5-link car is more prone to 'push-on' in the corners (understeer)...
oldrc
Post by oldrc »
I see. I don't think I would like any more understeer than what I used to get with my SE to be honest. Still, it's an interesting concept to mix and match on different tracks.
Bottom Feeder
Been thanked: 25 times
Post by Bottom Feeder »
I had done the same conversion a long time ago. I had a few higher-spec JRX and RC10s at the time but I bought a Junior-2 out of boredom. The 'Losi Link' rear suspension was pretty much outdated even by then but it sure did look cool as hell. As the OP's pics show, it just happened to look even better on a Junior-2 molded chassis!
LosiXXkid
Post by LosiXXkid »
It also gives you a massive headache when trying to find/ locate parts for your build.... :x
LosiXXkid
Post by LosiXXkid »
Some more progress with the Jr./JRX2 hybrid...
Losi 5-Link Hybrid (Side)
Losi (Update) 014c.jpg (125.91 KiB) Viewed 2938 times
Losi 5-Link Hybrid (Top)
Losi (Update) 016c.jpg (132.15 KiB) Viewed 2938 times
Losi 5-Link Hybrid (Rear)
Losi (Update) 011c.jpg (120.83 KiB) Viewed 2938 times
Losi 5-Link Hybrid (Trans Rear)
Losi (Update) 009c.jpg (110.16 KiB) Viewed 2938 times
Losi 5-Link Hybrid (Left Side Trans)
Losi (Update) 005c.jpg (120.42 KiB) Viewed 2938 times
Losi 5-Link Hybrid (VTS Slipper)
Losi (Update) 008c.jpg (106.5 KiB) Viewed 2936 times
Thanks go to Aaron for helping out with the suspension links that I needed and to eBay for the A-5001 Rear Shocks w/ Springs, Collars & Ends!
Return to “Losi Forum”
