Team Losi Junior T & Junior 2
Dangeruss
Has thanked: 425 times
Been thanked: 1410 times
Post by Dangeruss »
Team Losi Advertising their pair of newly introduced entry level vehicles:
Junior 2: 1/10 2wd off-road buggy released in 1990. Long wheelbase plastic chassis with top brace, 4-wheel independent suspension lower a-arm/threaded camber link up front and h-arms with threaded camber links in the rear. Also accommodated Losi's 5-link rear suspension. Servo saver integrated bellcrank steering. 48-pitch, ball-diff equipped, self-lubricating transmission with aluminum motor plate with 32-pitch spur gear. JRx2 shorter oil-filled anodized aluminum coilover shocks with adjustable spring collars on plastic shock towers. Jrx2 spoke plastic wheels (in white) Ribbed front and Spiked rear tires, plastic bushings instead of bearings and clear lexan buggy body. Sold as an unassembled kit less electronics and radio.
Junior T: 1/10 2wd off-road truck released in 1991. Same chassis, suspension, and drivetrain as the Junior 2 with the exception of a 48-pitch spur gear on the transmission, one piece 2.2 truck wheels with Ribbed front and Spiked rear tires, clear lexan truck body and Junior T specific body mounts. Sold as an unassembled kit less electronics and radio.
