Scratches in fiberglass
Does anyone know the best to get scratches out of fiberglass? Or is it possible?
- slotcarrod
- Been thanked: 45 times
Re: Scratches in fiberglass
Sand with different grades of sand paper, heavy to fine, and then polish with car wax. If scratches are deep, you are S.O.L !
Rod Littau
- Been thanked: 325 times
I think many fiberglass surfaces have a gelcoat top layer, most are probably not just raw fiberglass. If the scratched surface is otherwise nice & smooth, you could prep it for a bit of gelcoat to fill the cracks/scratches, then you polish the gelcoat layer smooth again, flush with the good surrounding fiberglass. I've never worked with fiberglass but I think that's how you'd repair deeper scratches or cracks. I found this tutorial that might be of help:
http://www.boatingmag.com/how-to/how-to-repair-damaged-gelcoat
- 1586 Views
Last post by JosephS
- 1586 Views
Last post by Brandon G
- 1158 Views
Last post by bscotti
- 1038 Views
Last post by CUDDZILLA
- 1749 Views
Last post by cautrell05
- 1317 Views
Last post by treehugger
- 1173 Views
- 894 Views
Last post by Dr. Robotnik
Dustydrone,
Mojeek [Bot] and 11 guests
