Fiberglass or graphite?
cautrell05
Post by cautrell05 »
The frankenbuggy build of mine uses a T2 rear shock tower. The old fiberglass one on there is somehow warped so the ends are forward 1/8-3/16 inch. I can get either a black glass one or a graphite one for the same price. Which one would be better to go with. I really dont see flex being an issue. The one on there now is plenty stiff. Durability is the main thing. This is a full on racer and with with spares not readily available I need it to last. Thanks guys.
Nick
littleVETTE
Has thanked: 6 times
Been thanked: 10 times
Re: Fiberglass or graphite?
Post by littleVETTE »
personally i would get a carbon fibre tower. they could take the abuse. the fiberglass towers are prone to breaking or cracking with a good wack.
it all depends on your budget and how you're driving your buggy around.
cautrell05
Well I still crash more than I would like. As for cost both are around $10.50 give or take a buck so thats not really an issue. I was under the impression that the fiberglass ones were more durable(flexable). However I have no experience with carbon towers thats why I asked.
Nick
littleVETTE
the fiberglass towers are cheaper and easier to find. and they are more flexable. keep practing til you got a handle on your buggy. then if you feel that you're doing good, without any damage to your buggy, move over to the carbon units. you'll save yourself some money in the long run. when you do you'll also notice a slight difference in a stiffer tower.
nonetheless i still run them (stock fiberglass) on my rc10t truck. because they're beefy thick. but then again, they aren't exposed like on your buggy. i got a body between the carnage and the towers.
hawgfanman
Has thanked: 14 times
Post by hawgfanman »
Is that a T2 tub? If so, that's crazy! I've never seen it used on a buggy. Very cool! 8)
soniccj5
Post by soniccj5 »
I would go with the stronger CF/Graphite. My shock tower broke at a race during practice and I could not enter the 2wd mod buggy class. :cry:
cautrell05
hawgfanman wrote:Is that a T2 tub? If so, that's crazy! I've never seen it used on a buggy. Very cool! 8)
Yep, that a T2 pan and rear tower. Build thread here- http://www.rc10talk.com/viewtopic.php?f=35&t=22423
However its not the first one on here. scr8p has a prettier one and I have stumbled across a few others at times. Its going through a few upgrades before the novak race next month. The 10.5 is coming out and a 17.5 is in. With a shorty pack and a few other tweaks it comes in around 1530 which is not bad at all for a full metal chassis and overbuilt bulkheads.
Nick
CUDDZILLA
Post by CUDDZILLA »
Carbon fiber if price isn't an issue. It just looks better with the black chassis. :D
