RC10 Classic Runner
MetalMilitia
RC10 Classic Runner
Post by MetalMilitia »
Here are a few pics of my RC10 Re-Re runner. Wanted to keep it mostly stock. Only upgrades are JConcepts bellcranks and 2.2 inch wheel conversions. Let me know what you think!
85Edinger
Re: RC10 Classic Runner
Post by 85Edinger »
Nice car!
If you've done any suspension tuning, please post your setup here:
http://www.rc10talk.com/viewtopic.php?f=38&t=35257
mikea96
Has thanked: 659 times
Been thanked: 878 times
Post by mikea96 »
Looks good! One suggestion move your rear shocks to the outermost hole on the arm so the shocks aren't standing straight up!
GodSpeed
Post by GodSpeed »
Looks nice. I definitely agree with the rear shocks location suggestion.
Two questions for ya:
1. What is the advantage of the JConcepts bell cranks over plastic counterparts?
2. What tires are those front and rear?
85Edinger
Post by 85Edinger »
I know you're asking him, but I can tell you that the advantages of an aftermarket bellcrank over the stock one are a little less flex, a lot less slop, less resistance, and most importantly greater durability.
If you decide you want to upgrade your bellcrank I suggest this:
http://www3.towerhobbies.com/cgi-bin/wti0001p?&I=LXDWHZ&P=7
Plus the four bearings to replace the bushings.
MetalMilitia
@GodSpeed
1. Durability and less slop are the biggest reason for upgrading the bellcranks. I saw an incredible improvement once I did so.
2. The fronts are Proline 4-Ribs and the rears are Proline Dirt Hawgs. Both are 2.2". Also have a set of Proline Calibers for dirt and track.
GodSpeed
Post by GodSpeed »
Thanks for the responses guys.
GodSpeed
Post by GodSpeed »
85Edinger wrote:If you decide you want to upgrade your bellcrank I suggest this:
Going from the original servo saver steering linkage to this, do I need all of those parts or just these (link below) if I have a turnbuckle, ball studs and ball cups and will order bearings anyway?
I don't have my car in front of me so I guess I'm mostly just asking if I need to order those aluminum machine screws as well.
http://www3.towerhobbies.com/cgi-bin/wti0001p?&I=LXEDYT&P=7
What size are the bearings? I'll get Avids for $1ea
Those Dirt Hawgs (strange name) look good for asphalt. Are they? Will they become slicks after 1 pack? LOL
85Edinger
Post by 85Edinger »
I think you would be good to go as long as you have extra screws. I'm pretty sure those screws are the same as all the others on the bottom of the car.
GodSpeed
Post by GodSpeed »
85Edinger wrote:I think you would be good to go as long as you have extra screws. I'm pretty sure those screws are the same as all the others on the bottom of the car.
The servo saver linkage is already mounted with 8-32 x 7/8 aluminum screws so I'm thinking I'm good to go.
MetalMilitia
The Dirt Hawgs are quite good on asphalt. I use them as my A/T tires on most of my vehicles. I would definitely recommend them.
ca-rj
Post by ca-rj »
I would also recommend the Dirt Hawgs. I use them on several cars for street use and they last quite a long time. They are made with Proline's M2 compound so they are much harder than their current off-road tires.
RC10 Short Arm | Novak Tempest ESC | Tamiya Torque Tuned 25T | Savox 1258 | Stealth Trans w/ Exotek Slipper Eliminator (geared 24/81)
RC10B3 | HW Just Stock Club Spec | Reedy 13.5 | Savox 1258
MetalMilitia
Here's a few pics with my new Turbo Mirage lid.
DaveM
Has thanked: 727 times
Been thanked: 26 times
Post by DaveM »
Nice one, I love the color!
Cheers, Dave.
