How do you fit regular wheels on the Frog?
golaebob
Post by golaebob »
I recently bought the tamiya adapter for rear and front wheels but I realized that it only works on the rear. Is there any way to fit regular wheels on front side of the frog?? Please help!
j-sou
Re: How do you fit regular wheels on the Frog?
Post by j-sou »
What do you mean by "regular"? What tires/wheels are you trying to fit? Pics might help here.
tamiya
Been thanked: 9 times
Post by tamiya »
he probably means 12mm hex :(
No, 12mm hex at front is only normal for 4WDs.
2WDs usually use the fixed axle and bearings in the wheels -you can fit Wild1/Fox wheels etc
There are some 3rd party adaptors that held the bearings and you could bolt on
front wheels from Hotshot (triangle 3spot hub)
golaebob
Post by golaebob »
Sorry I was talking about 12mm hex sized wheels. so Im thinking about getting http://www.ebay.com/itm/221244470523wheels but I dont know which tires I should get.
thanks guys!
keithrc
Has thanked: 20 times
Been thanked: 15 times
Post by keithrc »
Wouldn't the Fox/Wild One wheels fit? They're a larger diameter than the standard Frog wheels. I'm pretty sure you can get adapters for the rear wheels to fit.
Keith :wink:
TomEG
Post by TomEG »
Any SRB (Sand Scorcher, Rough Rider, Ford Ranger) incl. the re-re's will fit. As will the Fox/Novafox wheels.
tamiya
Post by tamiya »
SRBs use the 5-slice piedish that's like on Frog already.
Wild1/Fox need the 4-stud adaptor from the WildOne.
(Wild1 wheels are 2" rear, 2.2" front. Gives better ground clearance and makes Frog handle much better IMHO)
Any DT02 wheel set will fit once you've put on 12mm hex adaptor at rear.
golaebob
Post by golaebob »
Thanks! I really like the wild one size of the wheels :D I think im going to go with this set. Thanks guys! I will update with photos later!
Return to “Tamiya Forum”
