Looking for this Schumacher
Bandit13
Post by Bandit13 »
I'm looking for this Schumacher(pic below). But; with a battery configuration like this one(http://www.ebay.com/itm/291135825101?_trksid=p2055119.m1438.l2648&ssPageName=STRK%3AMEBIDX%3AIT). Also a beam style front end. Has anyone seen one or know where I might look? Also; does anyone know what it's called? Thnx!
Has thanked: 1737 times
Been thanked: 1145 times
Re: Looking for this Schumacher
The one you have pictured is a Schumacher SPC ("SPC Euro Champ" according to a picture I have). The one on eBay is the Schumacher 'C' Car. Kit numbers from Schumacher:
C200 'C' Car Rolling Chassis Kit
C204 "SPC Euro Champ" Rolling Chassis Kit
This information comes from the back cover page of the Cat XLS colour instruction manual.... I'm sure Terry.SC will be along shortly with more exact information....
Bandit13
Post by Bandit13 »
Thnx Alex!
V12
Been thanked: 100 times
Post by V12 »
You mentioned the beam style front end, I think you mean this one http://classicrc.wordpress.com/1-12/schumacher/schumacher-b-car/ This is the Schumacher beam front end used at a different car.
The Schumacher 1/12 car using this beam type was called B-Car.
V12 wrote:You mentioned the beam style front end, I think you mean this one http://classicrc.wordpress.com/1-12/schumacher/schumacher-b-car/ This is the Schumacher beam front end used at a different car.
Great work V12! I never knew there was a B-car!
terry.sc
Has thanked: 7 times
Been thanked: 157 times
Post by terry.sc »
Bandit13 wrote:I'm looking for this Schumacher(pic below). But; with a battery configuration like this one(http://www.ebay.com/itm/291135825101?_trksid=p2055119.m1438.l2648&ssPageName=STRK%3AMEBIDX%3AIT). Also a beam style front end. Has anyone seen one or know where I might look? Also; does anyone know what it's called? Thnx!
As others have said, you are describing a B-car.
The B-Car was a simpler version of the C-car, without the complex independent wishbone suspension. The one piece beam meant there were a lot less adjustments that could be done to the front end. You can see the B-car alongside the C-Car here.
The later version of the B-Car came without any front suspension and the chassis was drilled to fit the Associated RC12i front suspension.
Bandit13
Post by Bandit13 »
Yes that was it!
Bandit13
Post by Bandit13 »
This to was it. I had a wishbone setup at first. But; only for about 4-5 races. I then switched to the "B-Car". It suited my driving style much better and I tore up the tracks with this car. It was so easy to setup and adjust, if you ever had too. I could basically run a few laps, adjust the tweek and tires. The car was awesome.
BIG QUESTION???
Does anyone know where I can find one???
V12
Post by V12 »
I have not seen a B-Car since a very long time. There is just that True Tyres Tornado car with the B-Car frontend here with me atm.
Bandit13
Post by Bandit13 »
Have you got a pic? I would interested in seeing that.
V12
Post by V12 »
camlchris
Post by camlchris »
The B -car will not be cheap. :D :D :D
Bandit13
Post by Bandit13 »
Money want be the hard part. Actually find one that someone is will to let go of will be the challenge.
camlchris
Post by camlchris »
Bandit13 wrote:Money want be the hard part. Actually find one that someone is will to let go of will be the challenge.
I maybe able to CNC re-pro it. Are u interested ??
Been thanked: 3919 times
Have you tried Bob Stormer of Stormer Hobbies?
Return to “Schumacher Forum”
