Remove RIT die
Remove RIT die
I'm restoring a 1/12th scale Bolink Renegade. All the delrin pieces have been died with what I presume is RIT die. A process we used to make the plastic pieces look good. Unfortunately; I want to remove it to get the factory look back. I don't even know if this is possible. does anyone have any ideas. Or; am I just screwed?
- Been thanked: 498 times
Re: Remove RIT die
the parts you have that are dyed are nylon. Delrin is not readily dye-able. Unfortunately, the dye in about 99% of cases is NOT removable, so you are stuck with what you have, or dye it to a darker color.
- Been thanked: 325 times
Re: Remove RIT die
RIT makes a dye remover but it's probably not going to be too effective at removing the color; it's more for uncoloring nylon clothing.
Re: Remove RIT die
Yeah you are pretty much screwed if the parts have been dyed. One thing to note however is that Delrin (acetal) is quite dyeable. I have used it for nearly 25 years, and dyed it on many occasions. Maybe you had something else (jwscab) you mistook for Delrin?
Re: Remove RIT die
Thnx guys. Not even sure if I have the right parts know. I thought they were Bolink. Then Associated. Now I'm not sure either way. I've found good pics of the Associated. It's not them. I need to find pics of original Bolink. Until then, I'm not sure.
- THE H.P FREAK
Re: Remove RIT die
HI!... Post pics of what you want identified in the The Official "What is it?" Thread.
http://www.rc10talk.com/viewtopic.php?f=33&t=14461
Re: Remove RIT die
Well Freak that's just it. I don't know what it is. LoL! I have to figure it out first.
- Has thanked: 1080 times
- Been thanked: 3729 times
Re: Remove RIT die
That's the idea of that thread! Post a pic of what you have and we can identify what it is
Re: Remove RIT die
I can't seem to find the thread. Can someone give me a link. I've search for about an hour. Oh; and if it's that obvious, I'm blind and deaf!?!
- Has thanked: 33 times
- Been thanked: 1188 times
Re: Remove RIT die
H.P. Freak already gave you the link...... 3 posts above your last one.Bandit13 wrote:I can't seem to find the thread. Can someone give me a link. I've search for about an hour. Oh; and if it's that obvious, I'm blind and deaf!?!![]()
- 1132 Views
Last post by badhoopty
- 1491 Views
Last post by phaze1todd
- 682 Views
Last post by DMAT
- 36 Replies
- 3225 Views
Last post by Mazdaj
- 1138 Views
- 1941 Views
Last post by sk7
- 40 Replies
- 5457 Views
Last post by THE H.P FREAK
- 1929 Views
Last post by urpaldan
Users browsing this forum: Facebook [Bot] and 9 guests
