What is this belt pulley system for?
- Has thanked: 1129 times
- Been thanked: 3919 times
Re: What is this belt pulley system for?
Belt conversion most likely for Stinger mk1. Possibly Optima, but unlikely without revised gearbox and idler.
- Asso_man!
- Has thanked: 40 times
- Been thanked: 82 times
Nope this is a belt conversion set for the 834B that replaces the chain system (obviously)
Come and visit the stable
It would be nice to see a measurement, those pullies look too big for the 834b- and they have the 4 screw holes that have the same pattern as a kyosho gear diff
- Been thanked: 12 times
So, a few of these have been kicking around on eBay and were advertised for a yokomo dogfighter. Excitedly, I bought one but upon arrival I had a good look and I tend to agree with Jeff's comments. The pulleys are a bit big and are reminiscent of optima ones. However, I can't see how the gear would fit properly into the pulleys.
So now I'm less excited...I wanted a belt drive system for an 834b rebuild....
Oh, I lost the bid final seconds, and see it again.I think this is an interested design
I'm 99% sure it would bolt onto a case half of an optima. You would remove the chain side and leave the gear side intact. Same with stinger. You can see the cross pin fits in the gear side
It would be nice to get a belt measurement, then we could say for sure optima or stinger. The kyosho belt conversion for the stinger lacked a rear trans case, but the optima had one and added a simple pulley to control the belt. Aftermarket may have not deemed it necessary
- Regular Member
Hi these are the Cogs for a belt drive 834b I am still looking for the belt for it.
- Has thanked: 170 times
- Been thanked: 23 times
krate-mayhem wrote:Hi these are the Cogs for a belt drive 834b I am still looking for the belt for it.
Sadly you just missed that belt on Ebay.
- Regular Member
Thanks for the info,when I use to race it,it had to much drag so I put the chain and the sprockets back on.
I've given up looking for a belt drive system for the time being...I'm just going to keep it stock!
- 1709 Views
Last post by DTohill
- 812 Views
Last post by shodog
- 2109 Views
Last post by polarbear
- 2670 Views
Last post by RichieRich
- 2917 Views
Last post by stickboy007
- 2428 Views
Last post by isobarik
- 1065 Views
Last post by mk-Zero
- 34 Replies
- 3889 Views
Last post by treehugger
