bell crank part
- DMAT
- Been thanked: 4 times
bell crank part
Not exactly sure what to call it but its the part that your screw on to the car that allows the bearing to sit snugly.
im trying to find some alloy ones without purchasing a full bell crank kit.
Just trying to see if i can avoid putting out more money than needed getting the jconcepts one.
Re: bell crank part
The metal bearing posts like in the rps/losi alloy bellcranks?I have two of them if referring to them.Ive had them a while since the steering bellcrank was missing.Kinda hard to steer with no steer bellcrank !
don
- DMAT
Re: bell crank part
it might be called a stand off. either way its at 1/4" OD and screws onto a 8-32 screw.
Re: bell crank part
Has a nut shape at bottom and takes a short 8-32 screw to mount to chassis and reduced at top into threads sticking up.Use either black or white flat delrin nut on top to secure bellcrank.Thats what i have.
if thats what you need pm shipping info i send them to you.don
- 1578 Views
Last post by askbob
- 677 Views
- 1224 Views
Last post by REMJ666
- 1503 Views
Last post by campbuds
- 1071 Views
Last post by Bottom Feeder
- 2813 Views
Last post by woodall01
- 880 Views
Last post by Whiskers
- 674 Views
Last post by mytimac
