Aluminum wheel hubs
Aluminum wheel hubs
I am going through some spare parts I have and I have 2 different thicknesses of aluminum wheel hubs. Are they different for front/back or are they from different models? Also are these aluminum hubs still available?
- stickboy007
- Been thanked: 55 times
Re: Aluminum wheel hubs
Which aluminum hubs are you referring to? The stock yokomo hubs (gray color...not sure if they're aluminum?) or the Suzuki blue anodized hubs (with single hex nut to mount the wheel)? Both occasionally show up on eBay once in a while. If you're looking for the original hubs for the 870c, I have two sets I can sell you if you want.
As for the different sizes in the wheel hubs, my understanding is that the wider hubs go to the rear and the narrower hubs go to the front.
Stickboy x2
If you get your hands on a 870 manual it shows you what width is used for what. Plus alot of other helpful stuff. There one floating around in this site somewhere...
i think there is a scans thread somwhere which would have it.
If you need anything specific i can scan any pages you need from my manual. Its in english atleast!
Actually on the 870c the thicker one goes in the front and the thinner one on the rear in the stock configuration.. the stock rear wheels have a good deal of offset and the fronts have less.. got the manual from oOple myself.. I actually had them the way stickboy007 did until I read the manual..stickboy007 wrote:Which aluminum hubs are you referring to? The stock yokomo hubs (gray color...not sure if they're aluminum?) or the Suzuki blue anodized hubs (with single hex nut to mount the wheel)? Both occasionally show up on eBay once in a while. If you're looking for the original hubs for the 870c, I have two sets I can sell you if you want.
Shawn
- Has thanked: 170 times
- Been thanked: 23 times
flustorm99 wrote:Stickboy x2
If you get your hands on a 870 manual it shows you what width is used for what. Plus alot of other helpful stuff. There one floating around in this site somewhere...i think there is a scans thread somwhere which would have it.
http://www.oople.com/rc/manuals/yz870c/imagepages/yz870c001.html
http://www.rc10talk.com/viewtopic.php?f=82&t=8103
- stickboy007
I do remember eventually putting the larger hubs up front on the 870 (this was before my hex conversion), as the front seemed a bit narrow with the hubs the other way around. However, each version appears to have something different...
I'm looking at my '91 and '93 Works manuals right now. The '93 appears to have the same hub size/type front and rear. On the '91 Works, the front and rear wheel hubs are different, with the rear being the same as the '93 Works and the front having an offset in the hub that pushes the hub toward the center of the chassis. In the '94 YZ10 manual, the front hubs are narrower than the rear hubs.
Sheesh!
Sheesh!
hmmm I never noticed the wheels actually have different offsets?? hmmm going to have to have another look see...
- 600 Views
Last post by Big Boss
- 1063 Views
Last post by dinglem
- 789 Views
Last post by Dieseler
- 1362 Views
Last post by WC1982
- 814 Views
Last post by Lowgear
- 2009 Views
Last post by littleVETTE
- 769 Views
Last post by markt311
- 1543 Views
