jrx2 Bearing sizes
jrx2 Bearing sizes
Hey guys,
So i am pretty much done rebuilding my Jrx2...but i have a nice crunchy sound from the bearings on the rear end...I want to grab some avid's but i don't know the complete size...Avid asks for 3 dimensions... I know they are 8mm x 14mm, but what is the third dimension? Are they 8x14x4? Any help would be great.
- License2iLL
Re: jrx2 Bearing sizes
The dimensions are usually inner diameter x outer diameter x height.
Not necessarily in that order. Height would be if u layed the bearing flat. top to bottom.
sorry I dont know the sizes off memory. Try boca bearings they even have a kit for the jrx2....they usually pickup the phone first ring too. Not sure of holidays right now though.
Glad to be back in this hobby so many many years later. To see new things and to recollect on ALL cool vintage models!
As well as to BUILD :
http://www.rc10talk.com/viewtopic.php?t=27591
http://www.rc10talk.com/viewtopic.php?f=27&t=33429
- Charlie don't surf
- Has thanked: 356 times
- Been thanked: 470 times
The are not metric- but they are 3/16" I'D and 1/4" ODzuki250 wrote:Hey guys,
- mytimac
- Business Member
- Has thanked: 7 times
- Been thanked: 56 times
You are correct depending on the bearing you are trying to replace.zuki250 wrote:Ohh ok, i am just going by what the manual states
The A6902 is for the outdrive gears on the transmission. You need 4 total.
I prefer getting 2 of the rubber seals on one side kind for the two outer most bearings. They get lots of dirt in them if you use metal only bearings. Something like these- http://sabulatech.com/storefront/product.php?id_product=2029
But you should be able to get them from Avid or any other good bearing seller. Any of the 8x14 should work as long as not flanged. Yes the thickness is 4mm.
Dan
Thanks Dan...i actually have some that i used on my optima...so i will just swap those in..i should have waited to put the whole thing back together before i did it...hahah
- 4072 Views
Last post by Brat
- 1668 Views
Last post by raserx08
- 418 Views
Last post by aconsola
- 569 Views
Last post by philk
- 348 Views
Last post by civilguy
- 1275 Views
Last post by hudson hornet !
- 1123 Views
- 924 Views
Last post by USA-1
