Bearing sizes for a 6 gear RC10?
I searched the forums and internet and can't find a direct answer...What sizes and how many of each bearing do I need to outfit an original RC10 with the six gear transmission, no bellcrank steering? Boca Bearings has "kits" for the RC10, but the bearings and sizes were different for the regular old rc10 and the championship edition, which I thought would use the same and it threw me off...thanks.
- LowClassCC
- Has thanked: 108 times
- Been thanked: 171 times
Re: Bearing sizes for a 6 gear RC10?
six gear bearings
5) 3/16 x 5/16 flanged
2) 3/16 x 5/16 plain
1) 1/4 x 3/8 flanged
and i f you want to put the bearings on the outside instead of the dust sheilds....
2) 3/8 x 5/8 plain (same as the stealth outdrive)
- dsmith
- Been thanked: 4 times
what are the size of the bearings that go inside the rear hub?
are they long and flanged like the bushing?
im going to buy some
- soniccj5
You will need four 1/4 X 3/8 flanged bearings. Install them on the inside and the outside of the hub.
ED
ED
- dsmith
thanks soniccj5soniccj5 wrote:You will need four 1/4 X 3/8 flanged bearings. Install them on the inside and the outside of the hub.
ED
- Regular Member
This is a great thread....Anyone know the bearing size for the front wheels? I believe that looking over this thread, if I order all the bearing shown plus the ones for the front wheels, I should have all I need to replace all the bearing, correct?
- Has thanked: 36 times
- Been thanked: 1318 times
it depends on which front wheels you have. they could be either 3/16 x 5/16 flanged, or 3/16 x 3/8 plain.
- Regular Member
Thanks for the reply Scr8p. They are the original wheels and the bearings are flanged, so I'm going to order the 3/16 x 5/16 and hope for them to work.
- veghead211
- Regular Member
Does anyone know what size bearings to use on Houge bellcrank steering?
"Beer is proof God loves us and wants us to be happy." - Benjamin Franklin
"Great spirits have always encountered violent opposition from mediocre minds." - Einstein
1/4 x 3/8 flangedveghead211 wrote:Does anyone know what size bearings to use on Houge bellcrank steering?
- Has thanked: 7 times
I greatly appreciate this thread! I've been wondering about bearing sizes, but was embarrassed to ask about them since I figured the info. was somewhere!
Thanks again,
Steve
Thanks again,
Steve
- flipwils11
- Been thanked: 19 times
Which bearings do I omit from the earlier list above if I want to use the 3/8x5/8 plain instead of the dust shields?LowClassCC wrote:six gear bearings
you don't omit any bearings unless you do the mods in this thread:
http://www.rc10talk.com/viewtopic.php?f=38&t=13836&hilit=brass+tubing&start=15
otherwise, the outdrives will slide in and out.
another option would be to fill that space in the outdrive with a brass bushing drilled oversize.
with tolerances on bearings today, you probably won't notice any binding due to three bearings being in the assembly.
If you intend to run the 6 gear tranny, I'll suggest that you go on with the mod. It'll be alot smoother and you will have longer running time on the idler gears. I've done that on my 6 gear tranny and no regrets. PS: As long as you are not gearing up with brushless setup.
My collections:
Nikko Brat, Nikko Dictator II, Nikko Thunder Eagle, Kyosho Pure Ten Nitro, Associated RC10, Associated RC10T, Associated RC10 Graphite, Associated B4, Tamiya Tamtech 1/24 Porsche 962C, Tamiya Striker, Tamiya TRF 501X WCE.
- 564 Views
Last post by philk
- 1080 Views
Last post by DMAT
- 437 Views
Last post by RC104ever
- 1290 Views
Last post by zuki250
- 1271 Views
Last post by hudson hornet !
- 413 Views
Last post by aconsola
- 344 Views
Last post by civilguy
- 1664 Views
Last post by raserx08
Users browsing this forum: DotNetDotCom.org [Bot],
Tbot [Bot] and 2 guests
