running dual servos for steering, receiver setup questions
njdriver04
Post by njdriver04 »
please bare with me, I'm new to 1/4 scale never ran dual servos for steering, I have a three channel radio and reciever, I am not sure how to use the aux input for the second servo. Could I use a y cable into one slot on the receiver?
Diamond Dave
Has thanked: 699 times
Been thanked: 130 times
Re: running dual servos for steering, receiver setup questio
Post by Diamond Dave »
Y splitter it is. I run one in my 5th scale gas truck. The Clod as well. A cap on the receiver and a BEC would not hurt either.
Getting them set up to run in unison is the only hard part.
njdriver04
plug the cap in the auxiliary on the reciever? running it on a 2 stroke gas engine. any tricks to get the servos working in unison
romulus22
Has thanked: 900 times
Been thanked: 789 times
Post by romulus22 »
Cap= capacitor.
Just use a tie rod from horn to horn and they will work together and not seperate
njdriver04
i will take a picture of the front end, i'm not sure I can tie them in together.
njdriver04
where in the circuit would the cap be most efficient?
You can install it on the receiver in any unused channel or battery slot.
Diamond Dave
romulus22 wrote:Cap= capacitor.
Now that makes sense. Why did I not know this before.... :oops:
njdriver04
did you guys solder your own cap to a connector or did you order one?
Lonestar
Has thanked: 623 times
Been thanked: 171 times
Post by Lonestar »
get a rx pigtail, solder cap to pigtail, voila :)
njdriver04
there are two futaba S3305 servos on the front end for steering and a duratrax sx100 servo for the throttle and brake. Would these servos work with a JR R135 receiver and JR XR3i transmitter? I am a spring chicken with RC electronics forgive my ignorance =). These servos are analog so would I need a different receiver?
njdriver04
njdriver04 wrote:there are two futaba S3305 servos on the front end for steering and a duratrax sx100 servo for the throttle and brake. Would these servos work with a JR R135 receiver and JR XR3i transmitter? I am a spring chicken with RC electronics forgive my ignorance =). These servos are analog so would I need a different receiver?
also when I plug in the battery pack to the receiver, the servos move slightly then nothing
Users browsing this forum: No User AvatarAmazon [Bot] and 2 guests
