Trans ratio
- romulus22
- Has thanked: 900 times
- Been thanked: 789 times
Trans ratio
I'm using a GT trans in my car due to its lay down style. Looking to lower ratio to 2.25 if possible. Will the buggy gears fit the case of the GT trans or is the spacing all wrong?
- Phin
- Has thanked: 87 times
- Been thanked: 248 times
Re: Trans ratio
You've got a lot of room to move the motor with the motor plate on that car so maybe you should go to 64p gears and use a tiny spur and giant pinion.
64p can go as low as a 74t spur and a 65t pinion.
- romulus22
Re: Trans ratio
Right now my biggest combo is 69-50 with 48p gears. The 64p is fractionally better. I think I'm going to have to take a different route. My brain is conjuring up ideas already. Just to execute my idea without a mill, cough cough, to any home machinist out there
- romulus22
Re: Trans ratio
New question, is the top shaft gear a press fit gear or is it all one piece? One side looks solid the other looks like 2pc
Edit: spline pressed on gear
- 845 Views
- 717 Views
Last post by bearrickster
- 949 Views
Last post by amp_driven
- 1012 Views
Last post by RC Chick
- 1763 Views
Last post by allaircooled
- 1052 Views
Last post by joel45acp
- 621 Views
Last post by isobarik
- 5253 Views
Last post by kink
Users browsing this forum: DotNetDotCom.org [Bot] and 4 guests
