First (Vintage?) Losi in my Collection - Junior2
- mtbkym01
- Has thanked: 190 times
- Been thanked: 274 times
Just picked up a Junior2 buggy(Some of you may have seen it on ebay), will hopefully see it soon (posting from USA to AUS) but the pics look good. (Will post them when it gets here)
Looking for advice and info about these buggies, I understand they were "Budget" or "Entry Level" at their release. What is it about them that made it so?
Is the gearbox weak, plastic weak etc, etc.
Any info appreciated
- Has thanked: 100 times
- Been thanked: 205 times
Re: First (Vintage?) Losi in my Collection - Junior2
The Junior series from Losi in my opinion was the start of the high performance molded composite chassis racing kits. Prior to that high end racers would have looked at it and shunned it for not being graphite or fiberglass plate or aircraft grade aluminum. Those kits lead the way for the likes of the ProSE LXT Double X's and yes even the B2 and later.
What makes them entry level is basically bushings and shock towers, everything else on them were race quality. With the addition of bearings and a slipper they make very competitive buggies on par with the buggies of the era. You can also swap out the shock towers with Pro SE or LXT towers and add turnbuckles instead of the all-thread to finish the conversion to race vehicle. The LRM is a great transmission that can happily handle most of the motors you would race with now days with the only real weak spot being the drive shafts. Another member has found Traxxas Bandit driveshafts I believe can be slightly modified and end up even more durable.
Chris
Chris
Mini - T, LST, LST2, Crawler
Micro - Trekker, SCT, T
- mtbkym01
Thanks for the Info Chris, The buggy really caught my eye when trolling through ebay, in particular it's stance I think.
I've downloaded a couple pics from the Ad, I think i'd like to do my own body/colour scheme, but other than that the buggy looks really clean, I plan on fitting some electronics (brushed motor/esc & 2.4ghz) so as it's in a running state, but not run it very hard. Anyway, here's some pics:
Cheers, Kym
Cheers, Kym
- LosiXXkid
I saw that and thought that it looked great too - and very clean. However, if you're going to run it you might want to keep an eye on that chassis brace as there appears to be a small crack by one of the front mounting screws.
- mtbkym01
Yeah saw that too (although after I purchased itLosiXXkid wrote:I saw that and thought that it looked great too - and very clean. However, if you're going to run it you might want to keep an eye on that chassis brace as there appears to be a small crack by one of the front mounting screws.
- License2iLL
Nice almost too cherry to run. Id seal and air tight those wheels they could save your life one day if we're attacked by aliens....they would recognize their value and spare you.
Glad to be back in this hobby so many many years later. To see new things and to recollect on ALL cool vintage models!
As well as to BUILD :
http://www.rc10talk.com/viewtopic.php?t=27591
http://www.rc10talk.com/viewtopic.php?f=27&t=33429
Ha..i almost bought that...i made an offer and he countered with a good one...but i bought a different one instead
That particular buggy was in fact owned by yours truly! There's actually a thread called "Lil Ol Jr.2" that I posted. I sold it about a month ago to jaybayrc. He put a new body and gear cover and swapped the springs, but other than that it's exactly the way it was when I had it! My advice for running it with anything more than a stock brushed motor would be to upgrade to a slipper to save that LRM tranny. You can find the part on ebay, and I think there's gotta be a thread on here about it. I actually had plans to put a retro xx tranny in that one, but moved on to other projects. Glad to see it ended up with a fellow rc10talker! Btw jaybay does good work on his rides so i'm sure it's still in tip-top shape!
- mtbkym01
Excellent info thanks guys, it's good to know a bit of history about the buggy too, seems I got a pretty good example, cheers
- LosiXXkid
You can see how I've been upgrading mine in this link to my build thread:mtbkym01 wrote:Just picked up a Junior2 buggy(Some of you may have seen it on ebay), will hopefully see it soon (posting from USA to AUS) but the pics look good. (Will post them when it gets here)
http://www.rc10talk.com/viewtopic.php?f=27&t=32879
- 1494 Views
Last post by highwayracer
- 2169 Views
Last post by limestang
- 809 Views
Last post by RCveteran
- 1712 Views
Last post by DerbyDan
- 1099 Views
Last post by mikecel79
- 619 Views
Last post by bearrickster
- 1447 Views
Last post by knixdad
- 20 Replies
- 2591 Views
Last post by mrlexan
