aluminum RPS servo saver posts replacement
- njdriver04
just wondering if anyone is running the rps alum servo saver without the original post, i'm missing one post and the other has a seized screw in it. anything from a local hardware store or other rc car? any place I can source some?
- Has thanked: 170 times
- Been thanked: 23 times
Re: aluminum RPS servo saver posts replacement
njdriver04 wrote:just wondering if anyone is running the rps alum servo saver without the original post, i'm missing one post and the other has a seized screw in it. anything from a local hardware store or other rc car? any place I can source some?
You can use the parts in this RC10 re-re steering kit.
http://www3.towerhobbies.com/cgi-bin/wti0001p?&I=LXDWHZ&P=ML
- njdriver04
- Been thanked: 4 times
- njdriver04
managed to drill the seized screw out of the post. so im good. When mounting the posts should I put a washer between the pan and the post?
TO SAVE THE ANNO I WOULD.Be sure to use the correct size screw for the posts its a shorty and dont force one tighter or seize up.don
- njdriver04
yea, figures I have so few of the shorty screws, was able to find two. I am a newbie working on RC cars, I havea lot more knowledge setting up automotive suspensions than rc suspensions but the geometry principles are the same anyway, how should i have the rps servo savers aligned when I trying to get the length of the linkage between the two. should all four ball ends be aligned in a straight line?
Make the center link long enough that the steering arms are parallel. This places the outer balls slightly outward and back from the inner set of balls.
- 1058 Views
Last post by rcflyer1984
- 906 Views
Last post by SmallScaleSmitty
- 939 Views
Last post by PBR Allstar
- 2006 Views
Last post by Phin
- 884 Views
Last post by Lonestar
- 568 Views
Last post by badhoopty
- 20 Replies
- 2584 Views
Last post by Halgar
- 2746 Views
Last post by joaquinva1
Amazon [Bot] and 8 guests
