2014 Nordic Indoor Vintage Challenge
Post about upcoming or past events.
Hcp22
Has thanked: 33 times
Been thanked: 22 times
Post by Hcp22 »
Saturday 1st of February 2014
Gillbergavägen 1
Eskilstuna, Sweden
Competition for vintage radio controlled 1/10 scale buggies, held indoors on a carpet track with mild jumps.
Sponsors
-- Rules --
Classes: 2wd, 4wd and Classic 2WD
2WD:
Models limited to production year 1994 and earlier.
Minimum weight 1474g
Motor limited to 17.5T brushless.
No ESC limit but should be set to 0-timing/blinkymode and no reverse. Forward/Brake only.
Batteries limited to 2S LiPo or 6 cells NiMH.
Swedish Edition slicks-tires or Schumacher Mini Pin/Mini Spike with the studs cut off to act like slicks tires. Fronts are optional as long as the tires are studless and made for a 2WD buggy. Odorless tire traction additive is permitted.
Other electronics like radio, speed control and steering servo are open.
4WD:
Minimum weight 1588g
Motor limited to 13.5T brushless.
No ESC limit but should be set to 0-timing/blinky mode and no reverse. Forward/Brake only.
Rules regarding modifications to cars in 2WD and 4WD class:
Modifications are fine provided that the custom parts keep the original shape. If the motor is originally mounted in the rear end of the car the motor should continue to do so. Approved modifications could be copies of an original chassis but in carbon fiber, upgraded gears, other belts, and also repro parts and bodies.
Option parts that were on the market back in the days are also allowed. Do you want to run an RC10 with MIP 4wd conversion, you are welcome! Option categories that were not invented back in the days are banned, such as big bore dampers.
It can be difficult to find 2.2" rims with correct offset for your model, but don't worry, the rules does not regulate a maximum width within reason.
Classic 2WD:
Models limited to production year 1985 and earlier.
Minimum weight is free
Motor should be a Tamiya Sports Tuned. Same for all participants.
Free rubber tire without studs. Front ribbed tires are permitted. 2.2" wheels alowed.
Modifications are permitted as long as the car looks like it did when it was manufactured; also repro parts and bodies are allowed. Replacing a locked axle with a differential for instants is permitted. Time typical options as well.
Examples of cars: RC10 first version, Tomahawk, Scorpion, SRB, etc.
Other:
Re-releases / reissues of cars are okay to run with. Just be sure that the re-release doesn't have a modern chassis like the Sand Rover and Holiday Buggy. They come with a DT-02 chassis which is not allowed.
Race set-up:
3 rounds of qualifying, 5 minutes each. Top 2 results counts.
3 rounds of finals, 8 minutes each. Top 2 results counts.
Max 8 cars in each final.
Transponders:
To be able to participate you need a personal transponder of the AMB/MyLaps brand. All the red ones are supported. You might share transponder with somebody as long as you don't run in the same heat, same class works. You are all individually responsible for having a transponder mounted and ready before your heat starts.
Entry fee:
200 SEK for the first class
150 SEK for the second class
100 SEK for the third class
Time table:
To be decided
Tires:
The “Swedish Edition 1:10 Slicks” could be found in several Swedish hobby shops and here is an exampel.
http://hobbycity.se/product.php?id_product=1868
The registration is now open, so please feel free to sign up the race! https://swe.letsrace.se/races
Feel free to ask questions!
Cheers
Lars
My Feedback
Dirtdiver
Re: 2014 Scandinavian Indoor Vintage Challenge
Post by Dirtdiver »
Please post pics of this event as the majority of us will be unable to travel there.
Hcp22
Post by Hcp22 »
Ofcurse we will post pictures and movies after the event :D
Cheers
Lars
My Feedback
DennisM
Has thanked: 30 times
Been thanked: 62 times
Post by DennisM »
Check -
Looking good Lars.
Gone fishing
Bo Wallen
Post by Bo Wallen »
Hmmmm...........Is it open for half American half Swede ? feel I need to travel a little :mrgreen:
RedBoxRacer™
Hcp22
Post by Hcp22 »
Bo Wallen wrote:Hmmmm...........Is it open for half American half Swede ? feel I need to travel a little :mrgreen:
Well Bo, sins you are such nice guy I guess I’s alright… And you can crash in our guestroom if you want to. 8)
Cheers
Lars
My Feedback
j0pp3
Post by j0pp3 »
That would be so cool! You're welcome, Sir 8)
Cheers
Joel
Hcp22
Post by Hcp22 »
The lineup so far… and it’s still 3 month to the race! This is only guys from Sweden, and I know guys from Denmark and Norway are planning to do the trip to Sweden. I would love to see more guys/girls from countries nearby making a trip to Sweden and the race.
Note the lineup in 4WD… a MIP 4-10 Legend :shock:
Classic 2WD
1. Hpc22 - Kyosho Tomahawk
2. j0pp3 - Tamiya Buggy Champ
3. Bert - Kyosho Tomahawk
4. Moose-t - Kyosho Scorpion
5. JanF - Associated RC10
6. Lars_J - Associated RC10
7. JHD - Kyosho Scorpion
8. Hägget - Yokomo 834B
9. SHY - Tamiya Grasshopper
2WD
1. Hpc22 - Kyosho Turbo Scorpion
2. Mr. Orange - Losi XX
3. Twister - Kyosho Ultima -87
4. Mr. Green - Kyosho Ultima Pro XL eller AE RC10 Graphite
5. Bert - Kyosho Maxxum FF
6. Moose-t - Schumacher CAT eller Kyosho Triumph
7. Thompson - Losi junior two
8. JanF - Associated RC10 WC
9. Hägget - Schumacher Top Cat
4WD
1. Mr. Orange - Kyosho Optima LWB
2. j0pp3 - Kyosho Optima Mid
3. Bert - Yokomo Dogfighter
4. Tomas - Tamiya Top Force EVO
5. Moose-t - Kyosho Optima MID eller Kyosho Lazer
6. Lars_J - Associated RC10 MIP 4-10 Legend
7. Hägget - Yokomo Dogfighter
8. SHY- Tamiya B.A.R. Hotshot Evo II
Cheers
Lars
My Feedback
Hcp22
Re: 2014 Nordic Indoor Vintage Challenge
Post by Hcp22 »
8)
Cheers
Lars
My Feedback
Been thanked: 3919 times
Letting the fwd back in 2wd huh :mrgreen: too cool! 8)
LurkingCAT
Has thanked: 202 times
Been thanked: 271 times
Post by LurkingCAT »
Initially I couldn’t find the time to be in on this gathering in February. A bit of thinking and I couldn’t resist! Really looking forward to take the trip from Norway to Sweden together with SHY and meet you guys in Eskilstuna!
The Fox was my first real car, and I soon got a full Hot Trick conversion with RC10 shocks and Thorp drive line. Actually I was the only one known to have the Hot Trick Red Fox in Norway at that time. Custom fees and trades profit made Hot Trick awfully expensive here… Since it was a one of a kind, my car got the nick name Pensel Fox, as I used to be called Pensel one the rc car scene. I just thought this would be a fun drive to bring…
Still have my Hot Trick Red Fox but it's a part of the museum exhibit I made here in Norway (viewtopic.php?f=33&t=27601), so I will have to build a new one for the race. If I find the time maybe I will go for a 4wd as well. Problem is that cars I could have used suffer from being stuck in museum displays. The cars I have at home are mostly very much projects.
Thank you for making this real!
Hcp22
Post by Hcp22 »
Cheers
Lars
My Feedback
Hcp22
Post by Hcp22 »
Two sponsors have join the Nordic Indoor Vintage Challenge
Cheers
Lars
My Feedback
Hcp22
Post by Hcp22 »
Cheers
Lars
My Feedback
Hcp22
Post by Hcp22 »
The organizer has donated this new kit as grand price for this event!
Cheers
Lars
My Feedback
Return to “Racing News / Get-Togethers”
