Alloy Build (FINISHED) also, undecided on name.
DMAT
Post by DMAT »
so I'm finally getting my build together. a majority of parts are put together so far. Its just a test fit for the moment until I decide how I want to have this all anodized. Most of the parts I've deanodized and polished up to a mirror finish. There is nothing under the gear cover at moment aside from the top shaft sticking out.
Parts:
-stock chassis (ebay)
-alloy stealth tranny & spacers (toyranosaurus aka REC)
-stock motor plate (ebay)
-stock nose plate (ebay)
-alloy front/rear arms (barts parts)
-alloy rear shock tower (ebay don anodizer)
-alloy 1.02 front shock tower (ebay one off)
-b4 front onboard carrier (STRC)
-b4 rear carriers (drilled to 1/8" hinge pin) (STRC)
-b4 caster blocks (drilled to 1/8" hinge pin) (STRC)
-b4 shock bushing (close but loose fit) (STRC)
-traxxas rustler heatsink plate (STRC)
-b4 shock bushing (STRC)
-shock spacers (used on shocks, not sure on vender)
-rc10gt shock set (ebay)
-crp esc mount tray (ebay)
-sees direction rims 2.0 x 1.5 fronts and rears (dad's & granddad's cars)
-protech stub axles in front (ebay, customized heavily)
-alloy front bulkheads (atlas)
-alloy rear arm mounts (atlas)
-alloy antenna mount (atlas)
-bell crank set (ebay)
-alloy body posts (ebay)
-b4 battery heatsink (Integy)(removed from build)
-thin walled 2x1 channel cut to length (unmounted at moment)
-alloy Gear Cover (Integy)
-stealth slipper hubs (ebay)
-4-40 rod ends (rc4wd, 4-40 rods need to be shortened to use)
-roll cage upper (BermudaCustomDesigns)
-roll cage panels (BermudaCustomDesigns)
-HG alloy differential gear (ebay)
-1/4" CVD axle kit (MIP)
-b4 Shiny CVD's (MIP)
-Bearings (avidrc)
-6.4 mm brake hose p clamps (ebay)
-stealth tranny brace (Dhood)
- rear bulkhead (jwscab)
-wing (chophead/pargustore)
-screws (stainless steel from fastenal)
-Exterior body panels were home made.
Gears
-alloy differential gear (HG)
-steel idler (Robinson racing)
-B4 top shaft
-SC10 87t spur gear (hot racing)
-varying pinion gears (Robinson racing)
electronics
Reciever: Futuba 603FS
Servo: Turnigy MG959
Motor: Velineon 3500
Battery: Venom 7.4 2s
Esc: Traxxas vxl 3s
foots
Re: Alloy Build (test fit)
Post by foots »
Daauummmm!
clm
Has thanked: 100 times
Been thanked: 205 times
Post by clm »
foots wrote:Daauummmm!
Ditto
Mini - T, LST, LST2, Crawler
Micro - Trekker, SCT, T
vsefiream
Post by vsefiream »
Wow that is some eye candy!!
integra22t
Post by integra22t »
WOW it reminds me of the liquid metal termantor .. what kind of rims are you thinking ?
SFC K
Has thanked: 47 times
Been thanked: 9 times
Post by SFC K »
:shock: I think I died and gone to heaven!!!!!! That is beautiful!!!!
Jeff
flipwils11
Been thanked: 19 times
Post by flipwils11 »
I think I just had a heart attack. We're not worthy!!!!
DMAT
Post by DMAT »
all those seeming stupid tech threads had to add up to something. :lol: I know I couldnt do some of this stuff without y'all knowledge.
zleader
Post by zleader »
just amazing.
shodog
Been thanked: 91 times
Post by shodog »
Holy alloy moley. That buggies got the bling
askbob
Post by askbob »
Shiny and sweet!!
vwjuice
Post by vwjuice »
Holy hell that is awesome. You got everything polished up like chrome. Nice job.
sandkil
Has thanked: 795 times
Been thanked: 623 times
Post by sandkil »
Holy crap :shock:
preciouusss......
hawgfanman
Has thanked: 14 times
Post by hawgfanman »
Wowza! :shock: :shock:
LosiXXkid
Post by LosiXXkid »
integra22t wrote:WOW it reminds me of the liquid metal termantor .. what kind of rims are you thinking ?
...oh yes, the Cyberdyne Systems prototype T-1000 made from mimetic poly-alloy....
