Anybody have this part on a RR?
Not looking like it wants to fit with the cutout on the body.
I can space it out so the body clears, but the shocks are forward of the cutout.
Also any pics of the Race Prep Dual shock kit mounted?
RCH rear dual shock tower
- Y'ernat Al
- Has thanked: 7 times
- Been thanked: 17 times
Re: RCH rear dual shock tower
I'm sure they are not intended to fit with the abs RR body (without modification). Oftentimes aftermarket parts are designed to work best with other aftermarket parts, in this case they assume you've got a lexan RR body for example.
- shodog
- Has thanked: 3 times
- Been thanked: 91 times
It should fit with the stock RR body. I modified one to mount a larger shock in. But like Y'ernat said, if you were running one of these you were also probably running a cut down lexan RR body also. What you'll find when modifying your SRB is that your buggy won't fit the stock bodies when you're done
- 37 Replies
- 13233 Views
Last post by jaro
- 1098 Views
Last post by mikea96
- 946 Views
Last post by USA-1
- 840 Views
Last post by RC10resto
- 480 Views
Last post by bearrickster
- 662 Views
- 1090 Views
- 423 Views
Last post by bully
