Removing tape residue of a gold pan.
After a lot of searching ive found a decent stealth champ edition. Tub is in great great condition, it just has loads of tape covering the screws on the underside. Whats best for removing the residue without harming the anodising?
Thanks
Thanks
- Has thanked: 1129 times
- Been thanked: 3919 times
Re: Removing tape residue of a gold pan.
Have you peeled the tape yet? In other words, tape or residue are remaining?
If you haven't pulled the tape yet, use a hair dryer or heat gun, it should help remove the adhesive
If it's just the messy residue, I've used goo gone and wd-40, both work well and haven't hurt the anno on mine
No I havent peeled it yet, the buggy only arrived today.
Will try your method
Thanks for your help:-)
- DMAT
- Been thanked: 4 times
wd-40 has always been my favorite for getting rid off adhesive from stickers and tape. aside from metal on metal, i dont know much that will pull that anodizing off aside from some oven cleaner.
- LosiXXkid
Acetone or isopropyl alcohol work well for removing old sticky goo...if you've got some of course! Otherwise, WD-40 (as mentioned) works well too but it can get a bit slippery...!
- uniquenamehere
- littleVETTE
- Has thanked: 6 times
- Been thanked: 10 times
goo gone. pour a little over the area, use your finger to rub it in, let it sit for about 15 minutes or so, use a new razor blade to swipe away the tape residue. if it's still sticky just pour some more goo gone on a rag and rub away til it's gone. i finish it off with some rubbing alcohol.
My favorite is electric motor spray. Works very fast and won't hurt the finish at all!
- Been thanked: 5 times
Automotive wax and grease remover is the best all around adhesive remover, and also a very good cleaner/degreaser. The good thing about it is that it its highly inert so it doesn't hurt finishes or plastic (I wouldn't soak anything in it), the bad part is the fumes are pretty strong. Most auto parts stores have it, the Klean Strip brand calls it Prep-All.
- shodog
- Has thanked: 3 times
- Been thanked: 91 times
Another good degreaser adhesive remover is paint thinner. I use it to remove goo and degrease the nylon parts.
- Lonestar
- Has thanked: 623 times
- Been thanked: 171 times
yup same here, find a flat plate, spray some WD40 liberally on it, put the tub on, spray a bit more, after 24hrs the residue just goes off with a light rub with your fingertips (not even the nails)DMAT wrote:wd-40 has always been my favorite for getting rid off adhesive from stickers and tape.
Paul
- Has thanked: 100 times
- Been thanked: 205 times
I just have some automotive brake cleaner that I use... takes of just about everything but the anodizing and the stuff I have is safe for the nylon as well. 24 hours with a lubricating oil to remove what the brake cleaner takes off in seconds? Not going to bother
Chris
Chris
Mini - T, LST, LST2, Crawler
Micro - Trekker, SCT, T
- 2568 Views
- 812 Views
Last post by mtbnjim
- 2198 Views
Last post by Asso_man!
- 1277 Views
Last post by DarthRacer
- 31 Replies
- 5166 Views
Last post by Sixtysixdeuce
- 2180 Views
Last post by rc10absuer
- 1090 Views
Last post by RedScampi
- 976 Views
Last post by shodog
