Optima Limiter Gear Nut
I am missing the reverse thread nut that fastens the Optima limiter gear. Does anyone have a good online resource for finding these type of nuts? Am having a hard time finding a replacement. Thanks.
- DennisM
- Has thanked: 30 times
- Been thanked: 62 times
Re: Optima Limiter Gear Nut
I think Your best shot would be a hardware store or an old model aviation shop that carries Graupner or Robbe spares.
You use a M2,5 polyamid nut and force it on.
German ebay has a set of M3 links and rechts mutter, one of each, but this is not lock nuts.
Or You could buy a M3 links gewinde tap (reversed thread) at the german ebay.
I´ll check my local hardware store monday and see if they stock any reverse threaded lock nuts.
Gone fishing
- highwayracer
- Been thanked: 6 times
Don't force a metal nut on there because the shaft will break
If you can't find anything, the best thing to do would be to use a nylon nut (losi 4-40). The nylon ones from kyosho are too soft (and small) and may not hold. The PRM versions may work as well.
@DennisM, @Highwayracer
Thanks for the ideas guys. I hadn't considered a nylon nut. Can't seem to find the reverse thread M3 nut anywhere, even specialty shops.
- Has thanked: 100 times
- Been thanked: 205 times
They are not nylock... but
http://neweramodels.mybigcommerce.com/3mm-threaded-turnbuckle-nuts-set-of-six-6-pairs-total-of-twelve-12-nuts/
https://www.fastener-warehouse.com/product-p/293550.htm
-still searching-
Chris
-still searching-
Chris
Mini - T, LST, LST2, Crawler
Micro - Trekker, SCT, T
McMaster Carr has some left hand nuts
http://www.mcmaster.com/#left-hand-threaded-finished-full-hex-nuts/=oiyrom
http://www.mcmaster.com/#left-hand-threaded-hex-nuts/=oiytu8
You can alway take a normal nut and deform it just a bit to make it a lock nut.
- Has thanked: 170 times
- Been thanked: 23 times
highwayracer wrote:Don't force a metal nut on there because the shaft will breakIf you can't find anything, the best thing to do would be to use a nylon nut (losi 4-40). The nylon ones from kyosho are too soft (and small) and may not hold. The PRM versions may work as well.
x2 best bet for sure IMO.
Hey thanks for those links. Will check them out.
Appreciate all the great ideas guys. Just trying to get the nut so I can use the part.
- highwayracer
One thing I forgot to mention is that the RPM nylon nuts aren't threaded. They can be used for 4-40 or 3mm in either standard or reverse thread
I have an ot-74 limiter gear, and its fixed with a philips head screw. Is this not the same gear set? Were there different productions of the same part?
- Has thanked: 1129 times
- Been thanked: 3919 times
- Been thanked: 325 times
That doesn't sound right; there should be a threaded shaft protruding through the limiter gear, with the gear attaching with a gold-colored reverse-threaded nut. The original Optima gear (not the Turbo's OT-74 Limiter Gear assembly) is just a sold single part with the gear fused to the shaft, so no nut or screw. Also note that there are 2 kinds of OT-74; some had a thick, beefy spring while the other had 3 or 4 little spring-washers. They did the same thing but I've heard the beefy spring one was the better one.
More discussion on this gear setup is here:
http://www.rc10talk.com/viewtopic.php?f=30&t=17162
I've never owned the OT-74 with the spring-washers, though...only the thick spring kind.
Ahh, go figure, that's the variety I never owned, and the pic I found of it only shows the side view.
- 1406 Views
Last post by lebowski770
- 975 Views
- 1127 Views
Last post by Luckyracing
- 719 Views
Last post by crazy nick
- 1240 Views
Last post by EM1-TC3
- 2131 Views
Last post by rccars4sal
- 2287 Views
Last post by Hcp22
- 771 Views
